Results 1 to 6 of 6
Thread: installing a ridge ryder in gu winch bar
    Expert beansathome's Avatar
    Nov 2010
    deception bay (QLD)
    just some quick advice is it safe to put the ridge ryder 9000 pound winch in upside down?
    as the instructions say that it needs to be fed from the bottom but the rolers sit to high and lign up with it set in upside down ??
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Had a warn upside down in my last 4B, got full of water and stuffed it. The drain holes didn't point to the bottom so water got in and stayed there.
    Only found out about them when I bought a new winch.
    It worked fine though so I guess yours will as well
    Macca
    Nov 2010
    deception bay (QLD)
    Quote Originally Posted by macca View Post
    Macca
    Thanks for the reply macca. The drain holes is what I first thought of but I can't find any I could b blind lol.
    Advanced dasemm's Avatar
    Aug 2011
    Brisbane
    I put a 12000lb ryde ryder in my gu last weekend. I could not see any drain holes either.. you putting it in a nissan steel bar ?
    2004 ST GU4 TD42Ti
  6. #5
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    In the Warn manual it said to take the motor off, there is a slot that is sealed with silicon and one that is not.
    One of them has to be open and at the bottom and reseal the other with silicon.
    No idea about what you have though.
    Macca
  7. #6
    Nov 2010
    deception bay (QLD)
    Quote Originally Posted by dasemm View Post
    yep going into the steel bar. i got the 9000LB for round 300 cant remember exactly it was in there catalog a few weeks ago..
    Macca
    i should have taken some picks when it was apart.. i pulled both sides off i turned the clutch side so as it can be used maybe i should try figure out the same on the motor side.
    might pull it apart again tomorrow and have a good look im a little worried about striping it down and not getting it back together again.
