29th April 2012, 12:14 PM
#61
bastardo
mine seems to have no power some times, cleaned the mac but no difference. forgot to do reset though. second gear foot flat it just goes nowhere if revs are low. this normal?
You have probably already checked but it's an easy mistake. I cleaned my MAF and had no power after wards. Was stumped for a few min then realised I hadn't re plugged it in
29th April 2012 12:14 PM
13th June 2012, 02:24 AM
#62
mav345
this is not quite true some efi vehicles had a MAP sensor (Manifold Absolute Pressure sensor).
cheers mav
My bad, wasn't thinking, "clunk"
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
13th June 2012, 01:03 PM
#63
Thank you YNOT! I have a problem, I could not find the sensor cleaner in the market over here... I live in Bolivia. Would you know of anyother "cleaner" that would do the job?
3rd July 2012, 11:44 PM
#64
Hi all, Does anybody have some idiot proof instructions and advice for me on how to clean the MAF on a 1999 2.8.
Is it the same thing a the 3.0 info that YNOT kindly posted in this thread or something different ?
Please excuse ignorance - just learning, and thanks in advance for any info !
6th July 2012, 05:06 PM
#65
well i went out today to see if the MAF sensor was dirty or not
i installed the provent 200 catch can just before xmas ive drained a bit of oil of
a couple of times and thought id take a gander well well dry and clean as a new borns bum
it certianly works for me
18th July 2012, 06:29 PM
#66
HI Tony I have a 2005 gu with a ZD30 motor the maf part no is 22680 7S000, However the wire codes are different to those quoted by you , mine are looking from the front of the vehicle left to right
nothing, yell/blue,yell/gren,red,blk ie 5 connectors
Can you give me the voltages /details tks and rgds teago
18th July 2012, 07:15 PM
#67
Theres a 4 pin and 5 pin, I'll get you a part number for 5 pin $115 on fleabay
back again like magic, pt no on box is 22680-AD21A
19th July 2012, 02:19 PM
#68
Tks very much threedogs Cheers Teago
5th September 2012, 06:53 AM
#69
What if the red wire voltage reading is 13.8v?
That's what mine does. White is on 12 V which is the same as the battery voltage
29th October 2012, 05:47 PM
#70
Thought I had a MAF problem & acquired an engine management booklet. Free. Goodee.
Wiring diagram didnt show GU IV & then i realised YNOT had the colors worked out. Thank YNOT. Thought I was going to buy a MAF until I sorted the wires & colors out. Nissan want an exceptional quantity of $$$.
06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
