Results 1 to 10 of 11
Thread: Reading and erasing GU Patrol fault codes
    Infomation Courtesey of Repco Autotech Encyclopedia 2006
    NOTE; This information does not apply to 4.8 litre models.
    Fault Codes
    The 4 digit Fault Codes are displayed in two parts as flashes of the Check Engine Lamp.
    The first part represents the first two digits of the fault code.
    These are displayed as 0.6 second flashes.
    The second part displays the second two digits of the fault code.
    These are displayed as 0.3 second flashes.
    There is a 0.9 second pause between the first and second parts of the code.
    There is a 2.1 second gap between separate codes of different value.
    Multiple codes will flash in order of numerical value, from lowest to highest.
    Fault Code Erasure
    Fault Code Erasure can be carried out with a Compatible Scan Tool or manually.
    Manual Erasure:
    1. Carry out Fault Code Extraction.
    2. While the Fault Codes are being displayed, bridge Diagnostic Connector terminals 1 and 8.
    3. Wait at least two seconds.
    4. Disconnect the bridge between Diagnostic Connector terminals 1 and 8.
    (This will erase the Fault Codes from ECM memory)
    Should the above procedure fail to erase the Fault Codes;
    Disconnect the battery negative cable or remove power to the ECM for 24 hours.
    Ensure that other memory codes are known prior to performing this procedure.
    Fault Code Extraction can be carried out with a Compatible Scan Tool or manually.
    Manual Extraction:
    1. Switch ignition ON.
    2. Confirm the Check Engine Lamp illuminates.
    (The system will be in Diagnostic Test Mode I.)
    3. Bridge Diagnostic Connector terminals 1 and 8.
    Confirm the Check Engine Lamp extinguishes.
    4. Wait at least two seconds.
    5. Disconnect the bridge between Diagnostic Connector terminals 1 and 8.
    (The system will be in Diagnostic Test Mode II.)
    6. Read Fault Codes as flashes of the Check Engine Lamp.
    Do not switch ignition off during this procedure or the system returns to Diagnostic Test Mode I.
    Fault Code Table
    Code # Circuit and Status
    0102 Mass Air Flow Sensor
    Circuit, Sensor or ECM failure
    0103 Engine Coolant Temperature Sensor
    (excessively high or low voltage at ECM)
    0104 Vehicle Speed Sensor
    (signal not sent when vehicle is in motion)
    0203 Accelerator Position Switch (incorrect signal sent to ECM)
    Accelerator Position Switch fault or ECM failure
    0208 Overheating Fault
    Cooling Fan system failure, Engine coolant re-filling procedure not followed,
    Cooling system faulty, Engine lubrication problem
    0301 ECM 2, failure (calculation function is malfunctioning)
    Internal IC failure
    0402 Fuel Temperature Sensor
    (incorrect signal for fuel temperature received)
    Refer to Injection Pump Control Unit
    0403 Accelerator Position Sensor
    (out of range signal received from sensor or switch assembly)
    Circuit malfunction, Accelerator Position Sensor failure,
    Accelerator Pedal Dual Contact Position Switch failure, ECM failure
    0406 INT/AIR volume (excessively high signal from Mass Air Flow Sensor)
    Air Duct, Charge Air cooler, Variable Nozzle Turbo Charger Control System,
    Variable Nozzle Turbo Charger, Mass Air Flow Sensor failure, Circuit malfunction
    0407 Crankshaft Position Sensor
    0502 Battery voltage (excessively high voltage sent to battery)
    Incorrect jump starting, Battery, Alternator, ECM
    0504 Automatic Transmission Communication Line
    (ECM receives incorrect voltage from Transmission ECM)
    Circuit malfunction, Automatic Transmission ECM
    0505 No faults detected
    Monitored circuits are operating normally
    0701 Camshaft Position Sensor
    (incorrect signal from the Injection Pump Control Unit)
    Circuit malfunction, Injection Pump Control Unit
    0702 Top Dead Centre Pulse Signal
    0703 Pump Communication Line
    0704 Spill Valve Circuit
    0705 Pump Control Module
    Circuit malfunction, Injection Pump Control Unit failure
    0706 Spill Valve
    Circuit malfunction, Spill Valve, Injection Pump Control Unit
    0707 Fuel Injection Timing Control System
    Circuit malfunction, Injection Pump Control Unit failure, Poor fuel quality
    0802 Barometric Pressure Sensor (built into the ECM)
    Internal circuit malfunction, ECM failure
    0804 ECM internal input signal processing function malfunctioning
    ECM failure
    0807 Brake Light Switch
    Circuit malfunction, Switch failure
    0901 ECM Failure (calculation function is malfunctioning)
    Internal IC failure
    0902 ECM Relay (incorrect voltage received by the ECM from the relay)
    Main Relay malfunction, Circuit malfunction
    0903 ECM Internal input signal processing function malfunctioning
    ECM failure
    0905 Turbo Pressure
    Circuit malfunction, Charge Air Pressure Sensor failure
    1003 EGR Volume Control Valve
    Circuit malfunction, EGR Volume Control Valve failure
    1004 Fuel Cut System
    Circuit malfunction, Injection Pump Control Unit failure, ECM failure
    1401 to
    1408 Nissan Anti Theft System
    Diagnostic link connector, the white connector just to the left and down from bonnet release lever.
    Tony
    Last edited by YNOT; 5th September 2010 at 12:18 PM. Reason: making it easier to read
  2. The Following 16 Users Say Thank You to YNOT For This Useful Post:
    AB (20th December 2010), Bob (2nd December 2014), Bruce McGregor (17th April 2015), Finly Owner (11th September 2010), Goat (1st September 2012), gxr (25th January 2011), jay see (23rd July 2014), Maarten (29th October 2011), mav345 (25th April 2012), mopper (26th April 2014), my third 256 (29th October 2011), NZDaz (28th November 2011), tadpole (7th September 2011), twisty (29th April 2012), vk3mnm (10th September 2012), Wetty (19th May 2012)
    Beginner Claude's Avatar
    Feb 2011
    Gladstone QLD
    Spot on mate, great post.this is going to help me a dam heap. Thanks mate.
    Aug 2011
    exactly what i was looking for top info thanks tony
    Fairview Park SA
    Hi all,
    I have a Nissan Patrol 2008 ST and my OBDII connector doesn't have pin 1 connected. I only have 4,5,6,7,8,9,12,13,14,16.
    Does anybody know how to do this with the later Patrols???
    Advanced Maarten's Avatar
    Sep 2011
    Barden Ridge, NSW
    Thank you, Tony. This is much appreciated info.
    2006 Auto GU IV DX 3.0l TD
    Springwood, Brisbane
    Great info YNOT. Don't need it now but certainly great for future reference. Thanks
  9. #7
    hi are the terminals numbered left to right across the top and then left to right across the bottom?
    cheers mav
  10. #8
    Kinglake Victoria
    Cheers Andrew
  11. #9
    cheers bro
  12. #10
    Nov 2014
    Different style diagnostic connector
    Hi guys, I know this is an old thread but I'm hoping someone can still help me, or point me to another thread that is more helpful
    I have a 2000/1 GU TB45E Petrol Auto Patrol.
    I want to reset the Engine light so I can recheck for error codes. I have looked at this post and when I went to find my diagnostic connector I realised mine is different to the picture shown above.
    Mine looks like
    I have done a scan of my Gregory's Manual showing the two different connectors. The pink box shows what I have
    What pins do I use to bridge so the engine light resets. What do you use to bridge?
    I tried 1 and 8 but nothing happened. I tried 1 and 7 going by the colour of the wires and blew a fuse.
    All help appreciated
    Greg
