There's been a slight delay on this build, the RB25 that turned up had been leaking from pretty much every gasket. A replacement should be here today (fingers crossed).
I haven't done anything to the RB25 yet as I didn't know if it was going to be used, the owner wasn't happy when we called him up and asked if he wanted the leaks fixed while the engine was out. Apparently he bought a low km engine in "as new" condition, and was promised it would have no leaks.
Looks as though the RD28 flywheel will bolt straight on once the dowel is removed from the RB, having a heavier flywheel wont be such a bad thing in this installation. It will also allow the use of the RD28 starter motor.
The trouble with using the GU RD28 flywheel is it is a dual mass flywheel weighing 21kg, while it will bolt up and work on the back of a RB25 it was never designed to spin at 7500rpm which the RB25 is easily capable of.
Shown in photo is custom flywheel (on the left) which keeps the same thickness flywheel so the clutch face and ring gear stay in the normal position but only weighs 9.5kg. Machined from billet steel.
Tony
This dosen't have a duel mass flywheel. If it did, I would have pulled it out and thrown it in the bin. All they are is expensive getting upto $4000 for a non-repairable item. I've seen them fail in as little as 60,000km.
I would say the flywheel was replaced last time the clutch was done.
Hey Evolution any updates to this thread as its been a while n not much been put on here ?????
Cheers for any more info as I am also thinking of this in my GQ 2.8 if I gotta get a new injection pump & its getting long in the tooth with over 330k's on it. Maybe cheaper to stick 1 of these in.
Got the baby GQ a 1997 2.8TD RX Wagon Racetech EGT & Boost Guages Dobinsons coils 32in BFG KM2 M/T
