16th July 2012, 07:35 AM
Towing a Trol
HI all
Just reading throught the owners manual (as you do!) and it says the Trol should never be towed with any wheels on the ground - only put on a flatbed. Now I thought thats why the transfer lever had a Neutral position so you can tow it?!? Can anyone confirm and if you can't, what is the Neutral position for?
Nick
16th July 2012 07:35 AM
18th July 2012, 07:58 PM
If the T-case gets lubricated by an oil pump driven by the input shaft, then I would not tow it very far, as it may not get adequate lube.
I do not think this t-case would have such a pump but I could be wrong.
I would hapily tow my manual patrol with gearbox and transfer case in neutral at 60-80km/h for as long as I felt like it. I would check gearbox and t-case for heat etc during travel if I was concerned.
All parts that move due to towing (axles, diff, t-case) get lubricated from the wheels turning and splash lubing.
If it was auto, I would probably do the same.
I would probably lock the front hubs in so that front and rear inputs are the same.
Maybe a Nissan t-case guru can shed more light
06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
19th July 2012, 12:57 PM
a member of the menagerie
The questions that also need to be asked is it auto or manual, and how far are you intending to tow said vehicle.
I thought auto box cars had to be towed with the rear wheels off the ground if rear wheel drive and vice versa for front wheel drive.
Not sure how that would affect a 4 wheel drive Patrol.
Hopefully someone more knowledgeable than I can shed some light.
Mark
Proud former owner of a 1997 White GQ TD42 Patrol Cab Chassis with an after market turbo, now with over half a million k's and still going strong, that's had a heart transplant and now not owned by me
21st July 2012, 01:22 AM
Thanks Guys - yes it's manual, so was confused as to why it shouldn't be towed, especially if the transfer can be put in neutral too?!!?
