Results 1 to 10 of 18
Thread: Nissan Patrol Steering Wobble
    Expert 1peter's Avatar
    May 2011
    Caboolture QLD
    I have a 98 GU and it has the Nissan steering wobble which i "after reading through lots of threads" have discovered seems to be very common. Mine comes in at about 90 km's an hour and disapears at 110 or thereabouts. The difference with mine is that it isn't there all the time ? I can go for a drive on the highway and it will be there but, next time it won't ?? I am just wondering if anyone else experiences this ?? I should also add that the truck is bog stock with Bridgestone tyres.
    Aug 2011
    i have had same prob in a 83 mq camber shims fixed that. this time 4 weel bal, alins and big frustrations towing a van. i kept moving my front rims around one hole at a time. magic dont know if it will work for all. but 37000km later no more rubber wear or shakes. fingers crossed. o and that includes driving from darwin ,wa,vic qld and plenty of off road. i'm not always jentle
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    It could be a many of things mate, first off I would suggest getting a wheel balance and alignment and checking wheel bearings for play.. Also would be worth getting panhard bushes and tie rod ends checked
    Let us know how you go with it mate
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
    May 2011
    Caboolture QLD
    Ok thanks for the feedback, i will try one thing at a time and see how i go. Are you guys saying that you have had the same problem as me ?? Meaning that the wobble is there sometimes and not others ??
    Oct 2010
    Tatura VIC
    Yep I have had the same thing as you ever since I bought the car just over a year ago.. Since then I have had tyres balanced a couple of times, and re-done wheel bearings (I found nothing wrong with tierod ends or panhard bushes.. I have my troll currently sitting at work with diff fully stripped as am putting a new swivel hub kit though as hoping this will solve problems (swivel hubs were a lot looser than factory spec).. I have also checked power steering box for play and my castor is spot on for my lift.. Can't think of anything else that would contribute to wobbles and this is more or less my last step lol..
    You basically have to go through step by step until you find the source of the problem
    Fletcha
    Apprentice Sparky
  7. The Following User Says Thank You to big_fletch For This Useful Post:
    belzi82 (30th August 2011)
    May 2011
    Caboolture QLD
    Sounds like lotsa fun fletch.
    Advanced dasemm's Avatar
    Aug 2011
    Brisbane
    I have the same problem in my 04 gu, never been able to fix it, seems to be a nissan feature. My dads old GQ does it as well
    2004 ST GU4 TD42Ti
  10. #8
    Oct 2010
    Tatura VIC
    I'll let you all know how I go when I put my diff back together if it solves my problem.. At this stage it looks like it will as swivel hub bearings are stuffed.. Time will tell when its all back together though
    Apprentice Sparky
  11. #9
    Legendary timbar's Avatar
    Feb 2011
    perth
    I find if I rotate front and rear tyres every 10,000 kms it seems to fix the wobble but occasionally i thow a weight off a rim and need to get it rebalanced but my camber is fine and my alignment is good and my bearings i do ever 100,000 kms so yeah it still comes back i learnt to just live with it hahahahaha
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  12. #10
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Over the years I have found that having the front wheels balanced on vehicle helps a great deal.
    Not all Tyre Companies do this.
