22nd August 2011, 09:17 PM
Taipan Exhausts - fitting is SA
Has anyone in SA had 1of these fitted to their 3.0ltre - if so where did you have it fitted - and are you happy with the product / service?
Many thanks
Guido
22nd August 2011 09:17 PM
21st April 2012, 03:15 PM
Guido, Did you ever get any imfo about the exhaust if so how did it go.
Thanks craig
21st April 2012, 08:34 PM
did you buy it in a kit form? if so have a go at it yourself its not hard and you will save around $300 better in your pocket than theirs. just buy yourself the blue selastic the parts shop will know what you meen the kit should come with the flange gaskets and you don't need to change the gasket off the back of the turbo. the hardest part of the job is removing the heat shield that covers the turbo and dump pipe after that its easy because it can only go on one way so have a go! cheers......
2008 GU 2" LIFT, GME UHF BLACK KING WHEELS, SAFARI SNORKEL, LIGHTFORCE 240' KAYMAR DUAL WHEEL CARRIER STEINBAUER POWER, beaudesert 2 3/4 system, runva 11,000 comp winch.....
