Page 5 of 5 FirstFirst ... 345
Results 41 to 44 of 44
Thread: Tow ball failure claims another life
  1. #41
    Advanced ablast's Avatar
    Sep 2011
    Werribee Victoria
    It's funny how much emphasis is put on on rated D shackles. I wonder what the sheer rating on a tow ball is or if there is even a standard?
    I dont believe their is one. As they are designed for load stress. Not sheer...
  4. #43
    Quote Originally Posted by ablast View Post
    Yes there is, specifically A.S. 4177
    Towballs are required to pass sheer testing as follows
    3.1.4.4 Test Procedure for 50mm Coupling Balls
    The test coupling ball shall be attached to the test fixture representing the towbar tongue or lug according to the manufacturers instructions and a longitudinal static force of 66 kN applied through a correctly adjusted coupling body of sufficient capacity.
    NOTE: This testing force in kN is 2.27 t x g x 3 test load factor
    Bottom line is that to meet ADR's a 50mm Towball cannot deform or sheer below 66kN
  5. The Following 4 Users Say Thank You to the evil twin For This Useful Post:
    Bigcol (28th November 2015), mudski (28th November 2015), Playmoney08 (4th January 2016), rusty00 (1st December 2015)
  6. #44
    330 Post(s)
    I will just leave this here
