20th August 2011, 11:10 AM
Question on tyres
hey guys.
Ive just had my gq lifted 2inch , ironman all round.
At present it has 15in rims with i think 31x10.5x15 tyres
AFter the lift my fuel consumption went from 11.5 litres/100 to around 13.5
The original shock due to age, caused the tyres to wear wrong, making the steering wobble ( mostly between 85-100kmph)
Im wondering if when i replace the tyres what way should i go?
should i get new 15x8 rims and go 33's, or will that raise diesel consumption even more
should i source a set of 16in standard gq rims and run 16in tyres
should i stick with same size tyres i have
any suggestions appreciated ( btw 80% the car drives on tar and the odd trip up the beach)
20th August 2011 11:10 AM
20th August 2011, 11:23 AM
Patrol Guru
Lifing the car should not have done anything to the fuel consumption. Increasing tyre size will increase fuel consumption as now you need more force to turn the tyre. From 31" to 33" this difference should be minimal, but differs with hoiw you drve and your car. As for 15" vs 16" there is no real difference, I went with 16" as tyres are easier to come by in that size (285/75R16). The 33/12.5R15 is the most popular size in 33"s for a 15" rim and is around 1.25"s wider than the 285/75R16"s. The general move is towards bigger rims these days...
Hope that helps
They've done studies, you know. 60% of the time, it works every time.
20th August 2011, 07:08 PM
thanks for the tip.
i dunno why but fuel useage definately went up with the lift, around 2 litres per 100, i thought maybe a bit more wind drag
from people running 33s , can any1 tell me how much more fuel id go thru if i went to 33's?
also , alot of patrols came with 16in standard, would economy improve at all going from 15in to 16 inch rims? would it lower rpm sitting on 100kmhr ?
20th August 2011, 07:46 PM
20th August 2011, 08:56 PM
Dribble Master
I'm kinda thinking that it would be the type of tyre used not necessarily the size of the tyre that would affect fuel consumption...................... for example, a road trye would be better than and all terrain, an all terrain would be better than a muddy, etc etc............... again the wider the tyre, the more road resistance, therefore the higher the fuel consumption.......
I personally think.............. well I've bought a Patrol, they're big, heavy and thirsty, I bought it to have some fun in with the family and out and about with mates...... The fun factor far outways the cost of running the pretty little thing!!!! lol and we didn't buy these because they're frugal!!!! Just my thoughts
20th August 2011, 10:54 PM
yea true, id have thought like that 10 yrs ago too, but with rising fuel costs, carbon tax, and it being a daily commuter i have to consider fuel costs. if it was a weekend car it wouldnt be an issue
20th August 2011, 10:58 PM
Dribble Master
snake1978
true true mate, maybe i should be thinking that way to............. it's also my daily driver lol
21st August 2011, 07:01 AM
snake1978
thanks for the tip.
The size of the rims will have no affect on fuel consumption, it comes down to the rolling circumference of the tyre and tread pattern. As said above highway type tyres will be better than mud tyres, all terrains somewhere in the middle.
Tony
21st August 2011, 08:45 PM
If 80% is on road driving and the rest is beach work,i would think about either leaving it with 31's or maybe even going a 32/11.5R15.
With a 2 inch lift they won't look out of place.The only advantage to having bigger tyre's is ground clearance under the diff pumkin.Going to a 33/12.5R15 will increace fuel use and also affect the power.
A GOOD MATE WILL BAIL YOU OUT OF JAIL, A BEST MATE WILL BE SITTING NEXT TO YOU SAYING YEP WE F**KED UP
22nd August 2011, 09:37 AM
