19th August 2011, 12:22 PM
Performance Trivia
I thought I'd start this just to see who the Petrol Heads are here.
Some Interesting Top Fuel Dragster Facts:
One dragster's 500-inch Hemi makes more horsepower then the first 8 rows at Daytona.
Under full throttle, a dragster engine consumes 1 ½ gallons of nitro per second, the same rate of fuel consumption as a fully loaded 747, but with 4 times the energy density.
The supercharger takes more power to drive than a stock hemi makes.
With nearly 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into nearly-solid form before ignition. The cylinders run on the verge of hydraulic lock.
Dual magnetos apply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
At stoichiometric (exact) 1.7:1 air/fuel mixture (for nitro), the flame front of nitro methane measures 7050 degrees F.
Nitro methane burns yellow. The spectacular white flame seen above the exhaust stacks at night is raw burning hydrogen, dissociated from atmospheric water vapour by the searing exhaust gases.
Spark plug electrodes are totally consumed during a pass. After ½ way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F.
The engine can only be shut down by cutting off its fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in those cylinders and then explodes with a force that can blow cylinder heads off the block in pieces or blow the block in half.
Dragsters twist the crank (torsionally) so far (20 degrees in the big end of the crank) that sometimes cam lobes are ground offset from front to rear to re-phase the valve timing somewhere closer to synchronization with the pistons.
To exceed 300mph in 4.5 seconds dragsters must accelerate at an average of Over 4G's. But in reaching 200 mph well before ½ track, launch acceleration is closer to 8G's.
If all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs $1000.00 per second.
Dragsters reach over 300 miles per hour before you have read this sentence.
Top Fuel Engines ONLY turns 540 revolutions from light to light! The redline is actually quite high at 9500rpm.
To give you an idea of this acceleration, the current TF dragster elapsed time record Is 4.477 seconds for the quarter mile. This means that you could be coming across the starting line in your average Lingenfelter powered "twin-turbo" Corvette at 200 mph (on a FLYING START) and the dragster would BEAT you to the finish line FROM A DEAD STOP in a Quarter mile distance!
GU Series 4 Ti, 3.0 CRD Auto with extra bits
The Following 4 Users Say Thank You to fixer982 For This Useful Post:
Finly Owner (19th August 2011), growler2058 (19th August 2011), Maxhead (19th August 2011), Warnie (19th August 2011)
19th August 2011 12:22 PM
19th August 2011, 08:33 PM
Rotaredom
we love performance, check out our weekend at the drags http://www.nissanpatrol.com.au/forum...s-To-Give-Away
19th August 2011, 08:40 PM
SUCH IS LIFE
Cool, sounds like my 3.0l Patrol...lol
________________________
______ 2017 D-Max _______
15th March 2012, 08:55 PM
I thought this post might have had a few more comments on it...
I'm 100% revhead & hoon but I'm smart enough to know there's a time & a place for everything & normally it's "not" in town.
The only car I own that's not a V8 is my TB42E GQ, altho I could fit a V8. I seem to have been bitten by the 4x4 bug & am forever infected. I love my GQ!
Bjorn,
92 GQ, TB42E, Auto, Wagon, 3" lift
