Results 1 to 4 of 4
Thread: x link
    Expert makeitfit's Avatar
    Aug 2011
    Aberporth beach, west Wales, UK
    x link
    Me again
    Just watchin' some Patrol p*rn on youtube and saw a Patrol with some massive articulation
    It had an X-LINK on the front axle, but what is it please and why ?
    http://youtu.be/W2ZxbfIPgIY
    Y60 Patrol 4.2 d SWB in puke green
    2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
    Expert TuffTD42's Avatar
    Feb 2011
    Central West, NSW
    Its basically just a length of steel that is welded to the diff on a bush allowing it to rotate. The front mounts for the control arms are cut off. they are then bolted to the xlink. This allows the arms to move more independently of one another. You will get the same effect if you remove just one front control arm bolt. Best not drive on the road like that & take it easy until you get used to the vehicles handling. You will need to remove the front sway-bar to get the front to flex to its potential with that set up. You will also need longer shocks & then you may find the front springs will fall out. But there is springs about that will suit.
    Comes down to the design of the front end. the position of the control arm bush's is what restricts the front from flexing. Hence the xlink fix's that problem. Or you can get Superior super flex arms that allow heaps of flex not as much as the xlink but enough.
    Once you get the front to flex then you will have to contend with the ball joint over binding & failing & I have also seen pics of a counter shaft snapped clean in half from to much front end flex.
    First pic xlink, 2nd pic Superflex arms.
    The conspiracy theorists were right!
  4. The Following User Says Thank You to TuffTD42 For This Useful Post:
    NissanGQ4.2 (18th August 2011)
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    nice vid mate that's flexing alright!
    Such is the rule of honour.
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    I want that front end flex. yummmmmmmyyyyyyyyy
