Results 1 to 4 of 4
Thread: Fridge Slide
    Apr 2024
    Fridge Slide
    Hi All, looking for some info on installing a fridge slide directly onto the rear cargo floor any tips or tricks are welcome or best practices to get it in and secure.
  2. The Following User Says Thank You to EazyAz For This Useful Post:
    MB (9th April 2024)
    472 Post(s)
    G’day Mate
    Personally not a big fan of drilling into beaut wagon rear OEM cargo floors
    In a past life found that simply cutting a say 19mm ‘Structural Formply’ shape to suit your desired floor plan and afix it via existing OEM bolt holes there within creates a perfect starting base
    Up to your good self thereafter with screw choices versus weight loads less than 19mm screw depth
    Cargo Barriers A MUST
    PeeBee (9th April 2024)
  6. #3
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Agree. I have managed to have a combination bed/draws/storage (home made), frame to hold 2 jerrys (home made), and 2 fridge tie down points (home made) in the back of my Y61 wagon using only existing bolt holes all without needing a ply subfloor. And all have multiple fixing points.
  7. The Following User Says Thank You to Brissieboy For This Useful Post:
    MB (11th April 2024)
  8. #4
    Apr 2024
    Thanks Mate, I think I will opt for this, definitely don't want to be drilling holes into the floor if I can avoid it.
  9. The Following User Says Thank You to EazyAz For This Useful Post:
