Results 1 to 10 of 15
Thread: Cleaning chainsaw chains
    462 Post(s)
    So after a big session with my saw gutting wood, in particular green Stringy Bark I have found. The chains gum up with hard black crap and it was a pain to clean off. Until I found out that if I soaked the chain in water and a sprinkle of drain cleaner, after a light scrubbing with a brush, they came up like they’d never been used before. Unbelievable! I’m probably the only person in the world who didn’t know this but it works really well.
    Just thought I’d share in case I’m not the only person living under a rock.
  2. The Following 6 Users Say Thank You to mudski For This Useful Post:
    Cremulator (27th March 2024), Cuppa (27th March 2024), mudnut (27th March 2024), pearcey (27th March 2024), Plasnart (27th March 2024), Touses (27th March 2024)
    I find that just cutting wood cleans them up pretty good
  5. The Following User Says Thank You to Winnie For This Useful Post:
    PeeBee (29th March 2024)
  6. #3
    462 Post(s)
    I have found different timbers do different to the chains. Last weekend I spent 5 hours slicing up a fallen mountain ash. Its wasn't dry timber, the chain was still pretty good. Cutting wet Stringy bark, which has that real dark, almost molasses look to the sap, bakes on the the hot chain and refuses to come off. Using the drain cleaner cleans them up no worries.
  7. #4
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Thanks for posting!
    Never cleaned a chain yet, usually just lube and sharpen. Will give it a go now
    2008 CRD Auto Wagon
  8. The Following User Says Thank You to pollenface For This Useful Post:
    BigRAWesty (29th March 2024)
  9. #5
    472 Post(s)
    Sugar Gum’s by namesake used to give our little coupe sticky grief too @mudski Brother
    Hot soapy water around the campfire appeared to be best in the long run, please do be weary of harsh chemicals, many modern chainsaw bars do have pre-greased (unserviceable) rollers in their noses
  10. #6
    462 Post(s)
    All good mate. I'm not cleaning the bar with drain cleaner, just compressed air and a decent spray lubricant for that.
    MB (28th March 2024)
  12. #7
    462 Post(s)
    Quote Originally Posted by pollenface View Post
    Thanks for posting!
    It doesn't need a lot of drain cleaner, just a light sprinkle and then let the bubbles do their thing.
  13. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (28th March 2024), pollenface (28th March 2024)
  14. #8
    43 Post(s)
    If it works go for it I say.
    But once out the water throw it in a zip lock bag with some bar oil and bath it with lube for a week.
    The draino will be stripping all oil out of the pins and I feel like it'll wear out quickly..
    I usually store the sharp chains this way to so they are lubed ready to go in the field.
  15. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    Cremulator (3rd April 2024), MB (30th March 2024), PeeBee (29th March 2024)
  16. #9
    Expert Arfa Brayne's Avatar
    Jul 2016
    All sorts of screams will come from what I'm about to say..........
    "Use sump oil, and turn the chain oiler up full"
    Sump oil (engine oil) contains detergents. Plenty of oil helps the cut and cools the chain. Sap doesn't stick to oil.
    Most people won't use sump oil because it's "dirty and full of contaminants" and "it doesn't lubricate properly"
    They fail to consider that the dust, dirt, and shavings from cutting timber are at least 50x more contamination than sump oil contains
    And if it doesn't lubricate properly - well, what was it doing before you drained it from your engine?
    More wear and tear from a stingey "proper chain oil" feed than a good flowing sump oiler.
    I run a tank of sump oil per tank of fuel.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  17. The Following 3 Users Say Thank You to Arfa Brayne For This Useful Post:
    AB (5th April 2024), MB (5th April 2024), Touses (5th April 2024)
  18. #10
    109 Post(s)
    Quote Originally Posted by Arfa Brayne View Post
    Nice one. Helps light your fires too I bet
  19. The Following User Says Thank You to Plasnart For This Useful Post:
    MB (5th April 2024)
