Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Cleaning chainsaw chains
    109 Post(s)
    Nice one. Helps light your fires too I bet
    That actually reads differently to how it was meant to sound.
    Nice one Arfa. Good tip. Must be a bit more oil around than normal but sounds like a pretty good idea to me. 👍
  2. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    Cremulator (6th April 2024), MB (5th April 2024)
    472 Post(s)
    Thanks Arfa, will definitely be trying that ASAP Legend
  5. #13
    581 Post(s)
    Liking this bloke, thanks for your input Arfa!
  6. The Following User Says Thank You to AB For This Useful Post:
    MB (5th April 2024)
  7. #14
    472 Post(s)
    Agreed @AB & @arfaBrayne Legends
    Somewhat completely off topic a whisker past midnight
    If for some reason folks are not trying to smash out firewood 🪵 cross cuts and are say milling like Alaskan’s for long slabs.
    Too much heavy OEM saw oil will soak deep into every cut, highly recommend a second set of hands squirting say 25/75% ratio detergent/water on your bars nose tips
    Your slabs will need a heap less planing/sanding for greater returns
    PeeBee (6th April 2024)
  9. #15
    464 Post(s)
    Quote Originally Posted by BigRAWesty View Post
    If it works go for it I say.
    But once out the water throw it in a zip lock bag with some bar oil and bath it with lube for a week.
    The draino will be stripping all oil out of the pins and I feel like it'll wear out quickly..
    I usually store the sharp chains this way to so they are lubed ready to go in the field.
    Not sure if there is any detrimental issues to the chain using drain cleaner, I will look into this though to see if there actually is though. I do see this method used a lot on the Woodcutters, chainsaw users etc forums and Face Aches pages, so theres either a lot of dumb people out there, including myself (highly possible), or it just works. Without and damage. Once out they get a good soaking and rinse in WD40 or similar, then a 24hour soak in a tub of bar oil, then as mentioned, put in zip lock bags ready to go.
    I will give Arfa's method a go next as I have plenty of used sump oil here. I'm keen to see the results...
  10. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (8th April 2024), MB (9th April 2024)
