19th March 2024, 01:36 PM
Hi!
Hey forum!
Long time lurker, first time poster. Thought I'd introduce myself.
I have a 2007 CRD Wagon. Set up for touring with a bed in the back, 2" lift and 33s. Rear bar with jerry and wheel holders.
I have a big job ahead of me with resealing a timing cover. Please share if you have any advice!
Thanks,
Mars.
The Following User Says Thank You to Marsicles For This Useful Post:
19th March 2024 01:36 PM
20th March 2024, 07:14 AM
I recently did my timing chain/cover. There is a dowel at the bottom which makes it feel stuck when removing.
Getting to the timing cover is a relatively big job though. Suggest buying a new "genuine" tappet cover gasket to replace as they tend to leak as well. The genuine ones are supposedly a softer rubber than aftermarket which seal better, my original tappet cover gasket was leaking heaps. Suggest replacing all vacuum hoses in the process, mine were all perishing.
You will need a water outlet gasket (#110622W200) and square o-ring (#144652W201)
2008 CRD Auto Wagon
Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
20th March 2024, 03:29 PM
Welcome to the forum mate.
