Results 1 to 3 of 3
Thread: Hi!
    Jan 2023
    Hi!
    Hey forum!
    Long time lurker, first time poster. Thought I'd introduce myself.
    I have a 2007 CRD Wagon. Set up for touring with a bed in the back, 2" lift and 33s. Rear bar with jerry and wheel holders.
    I have a big job ahead of me with resealing a timing cover. Please share if you have any advice!
    Thanks,
    Mars.
  2. The Following User Says Thank You to Marsicles For This Useful Post:
    MB (20th March 2024)
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I recently did my timing chain/cover. There is a dowel at the bottom which makes it feel stuck when removing.
    Getting to the timing cover is a relatively big job though. Suggest buying a new "genuine" tappet cover gasket to replace as they tend to leak as well. The genuine ones are supposedly a softer rubber than aftermarket which seal better, my original tappet cover gasket was leaking heaps. Suggest replacing all vacuum hoses in the process, mine were all perishing.
    You will need a water outlet gasket (#110622W200) and square o-ring (#144652W201)
    2008 CRD Auto Wagon
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
