Results 1 to 10 of 19
Thread: Disconnecting GU "key in" warning buzzer
    1. Remove steering column shroud
    - 3 screws
    - remove key surround
    - with a small screwdriver, gently force the two shroud sections apart.
    Insert the screwdriver where the 2 stalks enter the shroud. Only the bottom section of shroud has to be removed fully.
    2. On top of the key cylinder 2 wires exit with black tube wrap, going to a white plug - for 4.2 models. For 3.0 models the plug is brown. This plugs into a white socket which is wrapped in foam around the black wiring loom. JUST UNPLUG IT!
    3. Replace the shroud
    4. Enjoy the silence
    Tony
    P.S. I copied this from another forum
  2. The Following 18 Users Say Thank You to YNOT For This Useful Post:
    Avo (4th May 2014), bindi (10th September 2014), Fwdpatrol (25th July 2015), LaughingBeagles (30th January 2019), mojo53 (6th September 2014), MudRunnerTD (1st May 2011), mulletgutts (25th July 2014), my third 256 (1st May 2011), nowoolies (1st May 2011), NT09ST (4th May 2014), Patrol-Guy (4th January 2014), Rodm (8th March 2020), Steve4wdin (19th February 2013), the ferret (29th April 2011), Toy-Eta (23rd July 2016), vk3mnm (13th September 2012), Willee (23rd July 2016), zaid-m (23rd February 2013)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Good tip, i too find them very annoying, only brand new car ive ever bought was a 98 Nissan Pulsar, that bloody key in buzzer thing didn't last even one day, and i dissconected it in the same manner as you described.
  5. The Following User Says Thank You to 04OFF For This Useful Post:
    YNOT (1st May 2011)
  6. #3
    Patrol God nowoolies's Avatar
    Perth
    Quote Originally Posted by YNOT View Post
    - 3 screws
    Tony
    thank you, oh thank you, ..... i gotta get you a beer sir
    im gunna go do this now...silence peace, just around the corner
    HELL NO !!!!!!
  7. #4
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    I am going to disconnect it in my Nissan Maxima. Bloody nuisance
  8. #5
    330 Post(s)
    Gather 1 x #2 Phillips head screw driver and 1 x #2 flat head screw driver and this mod will officially take you 6 minutes!!!!!!
    AWESOME. Thanks Tony!.. I had seen the thread elsewhere but never got around to doing it. But it is EASY EASY EASY!.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    YNOT (1st May 2011)
  10. #6
    Perth
    all done total silence ............................bliss
    again thanks Tony
    HELL NO !!!!!!
  11. The Following User Says Thank You to nowoolies For This Useful Post:
    YNOT (1st May 2011)
  12. #7
    Jan 2013
    Newcastle, NSW
    thanks for this, got to be the most annoying aspect of my patrol. Will be giving this a go in next couple days... silence is golden
  13. #8
    Advanced zaid-m's Avatar
    Jan 2013
    Salisbury, England
    Tony, even a whingeing pomm, says thank you very much. The silence is beautiful.
    Even in -2° conditions I was still able to do this in under 15 min. Thank you again.
    Zaid-M
    http://www.DefencePhotos.com
    1998 GR (GU) SE Shortie, 2.8 TD 6 Cyl.
    Full sized Tonka Toy
  14. #9
    Thank you so much, looking forward to some bloody peace.
    GU series 7, 3" lift EFS Elite with Dobinson springs all round, Dual Batt, roof rack with side awning, Safari Snorkel, Scan gauge, TaipanXP 3" SS Vortex Exhaust, Cross Country Intercooler upgrade, Dawes Valve, Stage 2 TaipanXP Chip, Catch Can, blocked EGR.
  15. #10
    Expert Lieney's Avatar
    Adelaide,SA
    This process is in the reference document but thank you.
    I wondered if i disconnected mine, if the headlight beep would still function.
    Yes it does.
    Did the same for another fellow, reckons he could have missed me. Pass..
    It's brilliant, so thanks
    06 GU IV Nissan Patrol wagon 3.0L, Tough Dog 2" lift, Xrox bar, 12k Mako winch, 33" muddies, 3" exhaust, Awning, UHF, drawers & fridge, custom sliders, DVDs, custom water tank and pump, rack etc etc.
    Now just in - GQ Shorty 4.2 petrol, UHF - but looking at turbo or V8 conversion
