Results 1 to 7 of 7
Thread: GQ Patrol headligh surround grill clips
    194 Post(s)
    The GQ Patrol has 2 plastic clips either side that clip the grill into the front guards. I am trying to locate the name and a supply of 4 of these as mine are pretty shot and grill does not marry up tight with the guards. I am not talking about the 4 units that run across the top edge of the grill - I have replaced those with a metal clip and screw, and these work well.
    I just cable tie the grill to the body, so that the bonnet clips I have mounted on the grill have something to anchor to.
    MB (14th February 2024)
    472 Post(s)
    Would be honestly keen to learn their name, availability too Philstar
    I’m thinking about changing over from $$ OEM to maybe a Hills-Hack Rough-Job cheaper variant via Bunnings/Ramset WallMates sawn off after insertion
    Apr 2021
    Brazil
    My GQ has none and currently uses tie-wraps to hold the grill (very nice and tight I may add), but I recon there are two types, one black and one gray. On the GU it uses only a pair of the black ones and none of the grays. Not sure if one of those is what you are looking for.
    Black ones:
    https://www.aliexpress.com/item/1005...Cquery_from%3A
    Gray ones:
  7. The Following User Says Thank You to BrazilianY60 For This Useful Post:
  8. #5
    194 Post(s)
    Thanks BY60, these dont look like the ones I think I need - will pull one off grill next time I am with it - maybe I am wrong
  9. #6
    194 Post(s)
    Could be a counter question at PAP I reckopn, or I try something like a hutsert but they are in a bugger of a spot to get to if trying to do a bolt up.
  10. #7
    194 Post(s)
    Thanks Craig, I will look at this option also.
