Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Mundaring Powerlines video
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    excellent vid and report
    Tim
  2. The Following User Says Thank You to Finly Owner For This Useful Post:
    GUte (14th August 2011)
    Expert GUte's Avatar
    Perth
    Quote Originally Posted by Gert B Frobe View Post
    I have a factory snorkle on my 09 wagon and have come across many posts of these being very average. Can anyone point me in the right direction of where these leak and the best action to take for sealing them.
    Track looked in fairly good nick too!!!! Top Vid mate excellent quality.
    At the airbox where it meets the snorkel, there is usually just a foam seal sandwiched in between (as was the case with this one that drowned) and there will be drain holes in the bottom that need sealing up.
    My advice would be to pull the airbox out and check for drain holes and seal them up, make sure all the joins in the snorkel are sealed and also seal the join where the airbox meets the snorkel if it already isnt done. If its already sealed this will be a good sign
  5. The Following User Says Thank You to GUte For This Useful Post:
  6. #13
    Perth
    Oh and thanks for all the thanks!!
    Choosing music was hard! I hope you liked it, tried to use something different
    http://www.youtube.com/watch?v=01VjnTfpOC8
    http://www.youtube.com/watch?v=KcY3UF6_IaM << my favourite song at the moment
    Both sung by John Garcia,
  7. #14
    Patrol God nowoolies's Avatar
    Perth
    top day out mate
    looks like you`s had a heap of fun
    thanks for the video
    now you got me worried about my factory fitted snorkle
    HELL NO !!!!!!
  8. #15
    Advanced Skull's Avatar
    Nov 2011
    Currently Rockingham WA
    Great vid bud. pretty sure I saw you guys up there. Was out with some guys from work. Was in 03 wagon, grey with 4" and bfgmuds, ally roof cage and bull bar. Was great weekend. mate blew his clutch. Did half the track without it. Had to nudge him off every light all the way home. Just a quick one on snorks. Mine had a 10mm gap betwwen the air box and the snork (THANKS TJM). Was probably like it for twelve months. Done some deep crossing too. The GU guard has captive nuts all the way around the snork on the inner guard from factory. God knows why the snork manufacturers are to lazy to utilise em. Made myself a flange that held the A/F Box to the inner guard and the snork vai these bolts. Had to pull the headlight to get to the lower ones ( ratchet ringys) but would take a head on with a D11 to open that up. Not sure about the drain bloking idea. The likely hood of you pulling enough through that to screw your donk is quite unlikely, however you do want it to drain if it did get in. There should not be enough restriction in your snork to pull water in that tiny hole. My opinion.
  9. #16
    Advanced brooks's Avatar
    Mar 2011
    Perth WA
    Thats some awsome footage man. looks like you had some good fun. last i went up there a couple of months ago I ended up snapping my rear diff link which made the drive home all the way back to Kinross really intersting and also lost my fan due to a water whole. But still ahd some awsome fun and up untill i broke my diff link i was putting my Dads mates hilux with front and rear diff locks, 4" lift and 35" muddies, myne only has 32's a 2" lift other than that it is stock. PS: the rigs are also perrrrty nice!!!
