Results 1 to 10 of 11
Thread: Ideas for running power to roof-rack?
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Hello all, as the title suggests, I'm looking for some ideas of how to run power to the roof rack. I'm not too excited about drilling into the bodywork up high in case of water ingress. At the moment it will be for some led lighting on the rack but possibly a solar panel in the future too.
    Any ideas or photos much appreciated
    .......from under the great down under.
    Hello from Under Down Under!
    Feb 2011
    Shed
    45 Post(s)
    Drill a hole in the roof
    Or run the cable through your barn door hinge side
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    This is how I did mine for the solar
    John
  5. The Following 3 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (11th October 2023), PeeBee (11th October 2023), taslucas (11th October 2023)
  8. #5
    194 Post(s)
    I had mine running out the corner of the front door pillar with a cut out in the pinchweld, was ok but looked crap. I changed to a hole in the roof with an aluminium junction box. This worked well and was heavily disguised behind the leg of the roofrack. Neve had an issue with water leaking and intended on simply putting a gromet in the hole if it ever needed to be removed. Ultimately it was not the easiest set up as it required the wiring to go inside the B pillar and the roof liner - ended up tearing the pillar plastic vinyl sheet. I like the idea of the rear cabin vent as its designed to shed water also.
  9. #6
    49 Post(s)
    This is what I'm going to do (one day)
    And this is how it is.
  10. #7
    330 Post(s)
    ARB sell a Gland specifically for this.
    In the GQ I ran it up the B Pillar and out the top of the rear passenger Door for many many years. With the last big build I drilled a hole in the roof and happy with the result. The roof rack is welded to Mt body and is never coming off. Water will never get in. I remember MegoMonster had his roof drilled by the Dealership on his brand nee GU, blew my mind at the time, but the lights are there forever.
  11. #8
    Aug 2011
    North West Tas
    56 Post(s)
    What is it that ARB sell?
  12. #9
    193 Post(s)
  13. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    BrazilianY60 (16th October 2023), MudRunnerTD (17th October 2023), PeeBee (16th October 2023), Plasnart (16th October 2023)
  14. #10
    330 Post(s)
    Check out this link and scroll down to BaseRack Wiring
    https://www.arb.com.au/roof-racks-ca...snippet-152532
    Check out the gland. I could not find it intheir list but it exists, ask your local ARB.
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    taslucas (17th October 2023)
