Results 1 to 7 of 7
Thread: Replacement key fob
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Replacement key fob
    Hi all, my genuine Nissan key fob has died. Local key shop says about $70 for a generic replacement, genuine Nissan is like $200. Any horror stories for cheapies like the one in the link below? Cheap and says you can program yourself. Any advice? (2000 GU)
    https://www.ebay.com.au/itm/29534073...mis&media=COPYScreenshot_20230921-132237.jpg
    .......from under the great down under.
    Hello from Under Down Under!
    461 Post(s)
    The genuine fobs are notorious for not working properly, even from new.
    I did this, all that time ago and is still working.
    http://www.nissanpatrol.com.au/forum...entral+locking
    taslucas (21st September 2023)
    Aug 2011
    North West Tas
    56 Post(s)
    Woah, I think only my fob is cooked. Am i reading it right that you replaced a whole lot more than a key fob? Did you have to?
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    There are several options around with the spring loaded key that work way better than the factory unit. I got mine on eBay and had a local locksmith cut the keys. Didn't need the NATS programming since I'd swapped the engine to TD42T.
    They work at a much further distance than the factory stuff and batteries last longer.
    John
  7. The Following User Says Thank You to jff45 For This Useful Post:
    taslucas (22nd September 2023)
  8. #5
    Morayfield, QLD
    13 Post(s)
    This is what I have now. With the original keys there should be a small metal tag with a number that the locksmith can use to precisely cut a key rather than use a key copying machine.
    John
  9. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (23rd September 2023), taslucas (24th September 2023)
  10. #6
    461 Post(s)
    Only because the Nissan setup is shite. I had endless issues. Changed it out and never looked back.
  11. #7
    Aug 2011
    North West Tas
    56 Post(s)
    So I went for the $38 cheapy off eBay. The fob itself is made with metal and feels like decent quality. The instructions to program it were easy to follow and it worked first try. Has a range of about 10 metres. So far so good sketch-1696154740445.jpgDSC_5199.jpg
  12. The Following 3 Users Say Thank You to taslucas For This Useful Post:
    Cremulator (2nd October 2023), jay see (1st October 2023), mudski (2nd October 2023)
