9th August 2010, 02:24 PM
Vacuum Leak,
Howdy all
i think my GQ 4.2 carby has developed a Vacuum leak in the manifold area somewhere.
wondered if there is a common area to look or if i needa rip it all apart and replace all gaskets and seals. (i Surley hope not ) lol...
thanks
Aaron.
9th August 2010 02:24 PM
9th August 2010, 02:50 PM
Administrator
Hi Aaron, you can spray around the manifold gasket when your engines running with a can of water dispersant to find out where its leaking.
If theres a leak then it will suck it in and your engine will rev slightly higher too then you know where the problem is.
Ok there is a simple way to find this if you have one......
Grab yourself a can of CRC or WD40 (with the little tube) & spray around the gaskets, vac hoses & joins (not all over the place just one area, join or vac hose at a time). If you have a rough idle coursed by a vac leak it will smooth out if you hit the leak until it sucks up the spray then it will start to idle rough again & to confirm spay it again & it should do the same & you will have found your leak.
Good luck
Paul
p.s Good onya Andy no posting what Im posting.......lol
9th August 2010, 02:57 PM
Administrator
Beat ya!!!
Same time though, mustve just snuck in..haha
But yours is probably better as everyone has wd40 or crc...hahaha
9th August 2010, 03:03 PM
Andy
Beat ya!!!
It all works the same way in principle so yeah what he said to kablea.....lol
9th August 2010, 03:44 PM
lol... Thanks Fellas.
i'll give it bash when i get home
Aaron
2nd September 2010, 08:22 PM
Howdy guys,
I spent Ages checking every gasket, hose, ect ect ect... stil no luck... But one thing i did notice is if i take one of the vac hoses off the manifold, the idle jumps up and she seam to run good, cept for the 1100 Rpm, on gas,
But on petrol, she wont idle at all ever... with out a bit of throttle. Vac hose on or off seamed to make no difference.
So i'm thinking it might not be a vacume leak.
Any advice would be great. Cant get it to my mechanic for a week... so i hope i can fix it this w/end. or at least figure out what it it doing...
Thanks In advance
Aaron.
2nd September 2010, 08:49 PM
Without see it in person I'd say the carby sounds like it needs a rebuild. What you have described is not an uncommon problem with TB42s running duel fuel & I've come across it quite a few times.
Paul
2nd September 2010, 09:26 PM
Hi and welcome Aaron. Do they have a PCV, it may be blocked? or am I totally ooff track? head tired tonight.
2nd September 2010, 10:26 PM
Finly Owner
Just checked the PCV Hoses, They are all ok, (Almost lost my finger down the hose) ROFL!
Aaron.
