Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Vacuum Leak,
    Beginner kablea's Avatar
    Aug 2010
    Vacuum Leak,
    Howdy all
    i think my GQ 4.2 carby has developed a Vacuum leak in the manifold area somewhere.
    wondered if there is a common area to look or if i needa rip it all apart and replace all gaskets and seals. (i Surley hope not ) lol...
    thanks
    Aaron.
    581 Post(s)
    Hi Aaron, you can spray around the manifold gasket when your engines running with a can of water dispersant to find out where its leaking.
    If theres a leak then it will suck it in and your engine will rev slightly higher too then you know where the problem is.
    Banned
    Ok there is a simple way to find this if you have one......
    Grab yourself a can of CRC or WD40 (with the little tube) & spray around the gaskets, vac hoses & joins (not all over the place just one area, join or vac hose at a time). If you have a rough idle coursed by a vac leak it will smooth out if you hit the leak until it sucks up the spray then it will start to idle rough again & to confirm spay it again & it should do the same & you will have found your leak.
    Good luck
    Paul
    p.s Good onya Andy no posting what Im posting.......lol
    581 Post(s)
    Beat ya!!!
    Same time though, mustve just snuck in..haha
    But yours is probably better as everyone has wd40 or crc...hahaha
    Banned
    Quote Originally Posted by Andy View Post
    Beat ya!!!
    It all works the same way in principle so yeah what he said to kablea.....lol
    Aug 2010
    lol... Thanks Fellas.
    i'll give it bash when i get home
    Aaron
    Aug 2010
    Howdy guys,
    I spent Ages checking every gasket, hose, ect ect ect... stil no luck... But one thing i did notice is if i take one of the vac hoses off the manifold, the idle jumps up and she seam to run good, cept for the 1100 Rpm, on gas,
    But on petrol, she wont idle at all ever... with out a bit of throttle. Vac hose on or off seamed to make no difference.
    So i'm thinking it might not be a vacume leak.
    Any advice would be great. Cant get it to my mechanic for a week... so i hope i can fix it this w/end. or at least figure out what it it doing...
    Thanks In advance
    Aaron.
    Banned
    Without see it in person I'd say the carby sounds like it needs a rebuild. What you have described is not an uncommon problem with TB42s running duel fuel & I've come across it quite a few times.
    Paul
  10. #9
    Jul 2010
    Waterford West Qld
    Hi and welcome Aaron. Do they have a PCV, it may be blocked? or am I totally ooff track? head tired tonight.
  11. #10
    Aug 2010
    Quote Originally Posted by Finly Owner View Post
    Just checked the PCV Hoses, They are all ok, (Almost lost my finger down the hose) ROFL!
    Aaron.
