Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: 2012 CRD Common Rail. Oil light coming on.
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Quote Originally Posted by Coldcomfort View Post
    I have had a quick look at getting to the RHS sensor. It looks like a prize PITA. Are there any tricks?
    BTW I have a scan gauge that shows no codes..... Also I had to move the car on the weekend. I ran it for about 5 minutes with no unusual sounds. (I'm looking for an excuse to install a V8 diesel )
    So I'm fairly confident that there is oil pressure...... So starting to think that I definitely have a dodgy RH sensor.
    This is an extract from a post I did back in 2017:
    Removed fuel filter and tucked fuel lines out of the way. Disconnected OEM Sensor elec connector, then from underneath used an open ended spanner and removed OEM Sensor.
    This is when I installed the VDO oil pressure gauge and T piece (2017). Can not remember if it is required to remove the fuel filter + brkt just for the changing out the sensor. But not much work to move filter out of the way.
    Not sure if u are thinking of installing an oil pressure gauge, just be aware that some Tee adaptors on eBay are too long. This is what I used:
    https://www.gauge-shop.com.au/produc...40415205195941
    Attached a couple of post FYI:
    My install sensor/T piece/VDO sender
    http://www.nissanpatrol.com.au/forum...DO-quot-T-quot
    Mod to starter top bolt cable bracket so to fit T adaptor
    http://www.nissanpatrol.com.au/forum...or-Bracket-Mod
  2. The Following 3 Users Say Thank You to Bidja For This Useful Post:
    BrazilianY60 (30th August 2023), Coldcomfort (31st August 2023), growler2058 (31st August 2023)
