16th August 2023, 05:01 PM
TB45e distributor resistor or power transistor
I'm pretty sure I know the answer but thought I'd put it out there for comment.
It's a TB45e motor. The distributor circuit -
The resistor, connected to pin 4 in plug F22, goes nowhere according to any diagrams I've seen but is wired to pin 2 of the ECU/ECM.
Just out of interest, does anyone know where the resistor is used and not the power transistor?
16th August 2023 05:01 PM
16th August 2023, 09:17 PM
I just found out that the same coil is used in some Mitsubishi's. Mystery solved.
The Following User Says Thank You to MichaelT For This Useful Post:
mudnut (17th August 2023)
