10th August 2023, 02:09 PM
10th August 2023 02:09 PM
10th August 2023, 02:56 PM
Could be done but won't come up anywhere near a pro job. If your happy with that, then go full steam ahead. Light thin coats, then spray some clear on it.
paxrobertus (10th August 2023)
10th August 2023, 05:31 PM
2-pak paints will always come up better, but does require the full setup. And they'll kill you.
If you're going rattle-can job, then prep, prep, prep.
If you can leave the panel in the sun or under a heat lamp until it's warm to touch, that's good.
Stand the can in boiling water until the can is warm as well. Shake it like it owes you money.
Mist coat first. This is literally as little as you can detect on the surface.
Follow the instructions for recoat-times, your next coats can be full thickness. But many light coats beats few heavy ones.
1989 LWB 5-Seat, TD42
The Following User Says Thank You to mihit For This Useful Post:
BrazilianY60 (11th August 2023)
11th August 2023, 09:46 AM
Patrol Guru
mihit
LOL. New one to my dictionary!
11th August 2023, 03:34 PM
mihit
Shake it like a polaroid picture.
Fixed it for ya!
MudRunnerTD (11th August 2023)
