Results 1 to 3 of 3
Thread: crank angle sensor
    Feb 2023
    crank angle sensor
    Hi im new here and just looking for some tips on replacing a crank angle sensor on a tb 42 efi 1993
    how difficult is it to do and is there anything i need to keep in mind.
    cheers
    Dec 2023
    Hello, Here are some general tips to keep in mind:
    1. Safety First: Before starting any work, ensure the engine is turned off and the battery is disconnected. This prevents accidental starts and electrical hazards.
    2. Locate the Sensor: The crank angle sensor is typically located near the engine's crankshaft. Consult the vehicle's manual or online resources to identify the exact location of the sensor on your specific engine model.
    3. Gather Tools: You'll likely need basic hand tools such as wrenches, sockets, and a ratchet. Additionally, have a clean cloth or rag handy to wipe away any dirt or debris.
    4. Remove Obstacles: Depending on the engine layout, you may need to remove certain components or parts to gain access to the crank angle sensor. This could include air intake ducts, electrical connectors, or brackets. Take care to keep track of any removed parts and their respective fasteners.
    5. Disconnect Wiring: Unplug the electrical connector attached to the sensor. Be gentle when disconnecting to avoid damaging the connector or wiring.
    6. Remove and Replace the Sensor: The crank angle sensor is typically secured with bolts or screws. Use the appropriate tools to remove these fasteners and carefully extract the sensor from its mounting location. Take note of the sensor's orientation for proper installation of the replacement sensor.
    gorilla tag
  4. The Following User Says Thank You to kevinadams For This Useful Post:
    PeeBee (28th December 2023)
  5. #3
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    If it's anything like the CRD, it will be easy to locate/replace with fan & radiator removed.
    2008 CRD Auto Wagon
    Factory snorkel, flashlube catchcan pro, 3" manta exhaust, hpd boost controller, dyno-tuned & egr deleted
