Results 1 to 6 of 6
Thread: GU Heater core removal
    May 2016
    8 Post(s)
    Hi all as usual I have a problem ...
    The heater core is blocked solid ....
    Now do you have to de gas the aircondition system ?
    Its a big job but, it just about un useable in the frosty weather
  2. The Following User Says Thank You to Tip12345 For This Useful Post:
    MB (24th July 2023)
    462 Post(s)
    No need to degas the system but its a full dash out job from memory.
  5. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (24th July 2023), Tip12345 (3rd July 2023)
  6. #3
    Apr 2021
    Brazil
    Full dash removal indeed. I used the instructions in the following video to remove my dash, and it turned out not to be a big deal.
  7. The Following 3 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (24th July 2023), mudski (4th July 2023), Tip12345 (4th July 2023)
  8. #4
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    As mentioned, no need to degas but full dash removal. It looks impressive but it’s not that hard. I did mine a few years ago by myself when I was only 75
    John
  9. The Following 6 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (4th July 2023), MB (24th July 2023), mudski (4th July 2023), Rossco (4th July 2023), Tip12345 (4th July 2023), Touses (4th July 2023)
  10. #5
    462 Post(s)
    Yeah not hard but time consuming as what I found was I was redoing some of the wiring at the same time while it’s all exposed. Which took longer than the job at hand.
    MB (24th July 2023)
  12. #6
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Wow, good video! I might do mine as well, just for fun
    2008 CRD Auto Wagon
  13. The Following User Says Thank You to pollenface For This Useful Post:
    MB (24th July 2023)
