Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Power loss
    465 Post(s)
    Quote Originally Posted by Big Girl View Post
    Thanks heaps Mudski, much appreciated. I did some research and will get under the bonnet this afternoon. Regards, Louise
    No probs. The original intercoolers are well known to leak. If it is, you will be leaking precious boost out hence giving you poor performance under load. Let us know how you go.
    Big Girl (26th May 2023)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Simple test. Remove the IC and tape up the inlet and outlet ports. Submerge it in a basin full of water and if it has a leak you will see the bubbles. WHEN (not IF) you see the bubbles - replace it with an after market IC. As I said - simple.
  5. #13
    Quote Originally Posted by Fouldsy67 View Post
    Manual and just found a box in the back with 3 carbys in it clutch is good no slipping there
    Private Message sent, regarding the carbies.
  6. #14
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Maybe silly question (I don't deal with anything younger than the age of consent... or with "little" engines...)
    But can the thing not be braze/weld repaired??
    1989 LWB 5-Seat, TD42
  7. The Following User Says Thank You to mihit For This Useful Post:
    MB (16th May 2023)
  8. #15
    Jul 2010
    Thurgoona
    7 Post(s)
    Quote Originally Posted by mihit View Post
    The original IC has crimped on ends. The crimps seem to be difficult to seal. It can be repaired - and a more efficient core installed - and welded on. Getting someone to do it is sometimes an issue. Often easier (and sometimes cheaper) to go aftermarket.
  9. #16
    Beginner Big Girl's Avatar
    Feb 2022
    Perth
    Finally got it onto a dyno - the boost solenoid is sticking. I shall do some homework before I replace it, just in case I need more than just the solenoid unit. Thanks for the lead, much appreciated.
    PS. The air hose to the rear of the intercooler had not been tightened when the head was replaced a year ago. After tightening, the problem was not as bad, but still there. I booked it in for the dyno diagnostic this morning. Hopefully this will sort it.
  10. The Following 2 Users Say Thank You to Big Girl For This Useful Post:
    mihit (27th May 2023), mudski (26th May 2023)
  11. #17
    Feb 2022
    Perth
    Update:
    Diagnosis, no codes, no idea.
    Confirmed she has a new fuel filter, air filter, MAF sensor, cleaned MAP sensor, new boost solenoid, new airlines, and we have cleaned the hoses thoroughly. Done everything conceivable in the boost lines.
    Another point: My other half recently found a Nissan Patrol for sale, with a boost problem. He made contact to ask about the boost problem - they don't know whats wrong, that's why it's being sold.
    AND my mechanic who did the testing had another one in only two weeks ago and they didn't resolve that problem either.
    I shall contact the local Nissan dealership and talk to one of their mechanics to see what I can learn. Next step will be collecting information on a thread for others to add to until we find the solution.
  12. The Following User Says Thank You to Big Girl For This Useful Post:
    mihit (26th July 2023)
  13. #18
    Feb 2022
    Perth
    Well, Big Girl still has a boost problem.
    She has the new MAF sensor (plus new air-filter and thorough clean out before it went in)
    New air-pressure hoses (the lot)
    A new Boost solenoid (apparently the new version is an upgrade from Nissan) - as recommended by the mechanic who checked for codes
    I removed the shim (trying anything now!)
    Installed a new fuel filter
    The mechanics recommendation: no idea - take it to Nissan...
    and now I'm ready to take her to a 'professional' dyno mechanic.
    I asked around, the word is: DON'T take it to the local Nissan workshop.
  14. #19
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Should have started your own thread but we are here now.
    So you have fitted a new vacuum solenoid, pull the hose off the solenoid end port (blue hose in my first picture) and connect in directly to the VNT Vacuum actuator, where the red hose is shown on the second picture:
    with eng at idle _ does the rod rise up with the lever hard against the vane limit stop screw?
    Still with engine at idle, pull the same hose off the VNT Vacuum actuator _ does the rod drop down to bottom of stroke (approx 10mm)?
    PS: before doing the above direct connection / vacuum test to the VNT Vacuum Actuator, u can check the rod/lever position with with vacuum solenoid connected as it is currently set up:
    eng at idle have the hose connected to the actuator "ON" and then pull the hose "OFF" and you should see the actuator rod rise and drop respectively. Y/N?
    Do this and we will then go from here.
