Results 1 to 7 of 7
Thread: Steering column bush
    Legendary
    194 Post(s)
    Guys, I noticed this plastic bush on the top of the steering column was absolutely shagged. Any idea what is actually called so I can source one? i will send the image to PAP as well, totally hard and perished.Steering column bush.jpg
    Patrol Guru BrazilianY60's Avatar
    Apr 2021
    Brazil
    2 Post(s)
    It looks to me like the one that stays on the bottom of the steering well and has a small pin over its race to unclick the turning signal lever. Was you turning signal coming off as expected after turning a corner?
    Legendary
    194 Post(s)
    Been over twelve months with it off the road, so cannot remember to be honest.
    Legendary
    194 Post(s)
    Has anyone got a secondhand steering column they dont want or are willing to sell? The guys at PAP are telling me the bush isn't a spare part, so I need to buy a whole steering column. Kicking myself as gave the spare steering column I had away. 1997 2.8 TD GQ wagon, odeally just after the top assy where the bush is
  6. #5
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Can the bush be machined out of teflon? I have gotten myself out of many a bind, by using a drill press as a lathe to machine plastic bushes.
  7. The Following User Says Thank You to mudnut For This Useful Post:
    mihit (14th April 2023)
  8. #6
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    I'll bet it can!
    Or nylon, or UHMWPE or any of the other good slippy plastics.
    I'm blessed with a lathe or three, but absolutely, cunning use of a spinning thing will make parts!
    Will probably have a couple notches (if it is for the indicators) which will have to be filed in by hand...
    - 1990 LWB Safari flatdeck, TD42 -
    - 1988 LWB 7-seat Safari, TD42 -
    1989 LWB 5-Seat, TD42
  9. The Following User Says Thank You to mihit For This Useful Post:
    mudnut (14th April 2023)
  10. #7
    Legendary
    194 Post(s)
    Thanks Guys, simply dont have the time or drive for this stuff, so bought the s/h steering column and popped out the bush which looked brand new and swapped it out. Another job resolved.
  11. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudnut (15th April 2023), Rossco (15th April 2023)
