Results 1 to 4 of 4
Thread: Glow plug troubles
    Aug 2011
    Beecroft NSw
    Angry Glow plug troubles
    Oops drowned my Gq a little bit and still not starting. I have checked my fuses and relays all ok. The Gregorys book talks about a glow plug control unit. Can this be bypassed or does anyone know how much for a new one, or where a seconhand one can be sourced?
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    oops, should raise these up high before attempting water crossings. I believe approx $350 to replace. Auto elec should be able to source one.
    Tim
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Have you checked that you are getting power to the glow plugs?
    Did you check the fuses inside the vehicle?
    How far in the cab did the water get?
    If you have 4.2 you can bypass the grow plug control unit by supplying power to the glow plug relay (making the relay switch on).
    If you have the 2.8 these are a bit harder to bypass because they have a dual glow type set up.
    Benarkin QLD
    First two things to check
