Results 1 to 10 of 10
Thread: 2012 CRD Timing chain life.
    Yea, Victoria
    Hi all, is there a end of life schedule for the timing chain on a 2012 CRD wagon?
    Cheers all.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    If you get a hunch and want to change it, here's a cool video
    2008 CRD Auto Wagon
    Yea, Victoria
    I've watched that before. I'm not sure that I'm up to it. Also I don't want to do it unless there is a compelling reason. My truck has just passed the 250k mark and I'm just making sure that any sudden surprises are not coming my way.
    461 Post(s)
    Does your service manual say anything about it. If anything the chain tensioner might need replacing at certain klms...
    Yea, Victoria
    461 Post(s)
    Quote Originally Posted by Coldcomfort View Post
    Yer I'd be leaving it alone...
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    I've got a 2012 CRD and know a Nissan Mechanic, there is no scheduled timing chain change listed. He advised to leave it alone. I aked him to check as I was doing my hoses and serpentine belt.
    Jack
  9. The Following 2 Users Say Thank You to jack For This Useful Post:
    Coldcomfort (8th March 2023), mudski (7th March 2023)
  10. #8
    Legendary Alitis007's Avatar
    15 Post(s)
    Timing chains don’t have intervals at all. If your engine oil has been changed regularly and you’ve been quality oil then you shouldn’t have any problems. A customer of mine has an early di with over 350k on his zd, it has mass amounts of blow by and at one point was dieseling on it’s own fumes till I fitted a proper catch can but still no timing chain noises.
  11. The Following 3 Users Say Thank You to Alitis007 For This Useful Post:
    Coldcomfort (8th March 2023), growler2058 (8th March 2023), jack (9th March 2023)
  12. #9
    Yea, Victoria
    Thanks guys. Thats what I was hoping the case would be. I'll be leaving it alone for sure. But I'm glad I asked.
  13. #10
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Can't speak to your specific engine, but the Mitsubishi ute I had running a timing chain was spec'd for "checking" at 300k. It was a duplex chain IIRC driving the balance shaft and cams (hydraulic tappets)
    There may or may not be a spec available for your engine...generally given as a length over 10 links. But basically if you lay it out in a line and can feel any slop when you push-pull, it's poked.
    By the time your chain is "making noises" it's already past-worn.
    It could well go a million miles without catastrophic failure, but your timing, balance, economy etc will all be to shit.
    1989 LWB 5-Seat, TD42
