Results 1 to 6 of 6
Thread: Drivers door will not lock with FOB
    Yea, Victoria
    Hey all, is there a common or known issue with the drivers door not locking properly with the FOB or key.? I have to lock it by crawling across from the passenger side and then locking the passenger door by the old hold the handle up when closing method.
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    Mine's the same. I have been using the primitive "put the key in and turn it" method for the past couple of years.
    2008 CRD Auto Wagon
    462 Post(s)
    Yep common issue, a lot of people have issues still even after buying a new Genuine FOB. I just replaced the entire central locking control module with an aftermarket one. Took a whole 20 minutes to do, never looked back.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Did the same as Mudski years ago. Bought a unit from Jaycar and integrated it into the Patrol wiring. Worked great and was cheap to do. Have a search for how-to-do-it info on this forum.
    Mar 2016
    Nandewar Ranges, NSW
    10 Post(s)
    Mine is the same.
    Won`t lock drivers door on first click of the fob. Have to hit lock, open drivers door & close again. Hit the lock button & all doors lock. All doors lock fine using the key.
    462 Post(s)
    Heres a walk through on when I did mine many moons ago...
    http://www.nissanpatrol.com.au/forum...entral+locking
    Cremulator (2nd March 2023)
