Results 1 to 3 of 3
Thread: Fault causing unwilling engagement High/Low gear
    Apr 2023
    This has been an expensive mystery of an issue in my y62 patrol 2013 v8 320hp AWD.
    It started when the dealership replaced my ecu and actuator motor belonging to the transfer case to solve a lag issue.
    Afterwhich they told me the transfer case needs to be replaced.
    Finding them and the price ridiculous, got a used one installed only to find out the fork that holds one of the gears inside is broken.
    The symptom here was the heavier gears wanting to engage when the car is not level meaning descending or ascending while I'm driving in normal mode speeds around 70-100 kmh.
    A disturbing sound would come from underneath like gears grinding tips. And the problem would clear as soon as I hit the gas pedal.
    We replaced the broken fork, but the problem still is. Could it be a software issue since something is clearing when I hit the gas.
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Probably a stupid question but are we talking auto? manual? Is there not a lever you can pull to do things? Or is it all computer?
    What the heck is All Wheel Drive??
    Sorry, probably not much help... I mostly/only deal with older technology, cos I like things simple.
    1989 LWB 5-Seat, TD42
    80 Post(s)
    Get a hold of a diagnosis tool, plug it in and let it read any fault codes. These days compatible diagnosis tools are quite cheap.
    Doing this will either prove or indicate the electronics as the problem. My thoughts are that the transfer case you have purchased has been abused.
    Hopefully there is a simple fix for your problem.
