Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: EGTS Up Why?
    May 2016
    lower west victoria
    30 Post(s)
    EGTS Up Why?
    Since doing the Canning, the EGTs on the 3 litre CRD are up higher than they've ever been.
    Used to very rarely see it hit 600, now it's only got to be in the mid twenties and it hits 600.
    On the Canning we suffered through very nasty corrugations, lots of mud and water.
    I think the exhaust is now emitting fuf fuf fuf noise instead of the normal bop bop bop, which sounds like an exhaust leak somewhere.
    So the question is, what can make the EGTs increase?
    Restricted exhaust? Mud caked radiator? Buggered EGT probe? Leaky exhaust? Leaky join at dump pipe?
    I've also noticed an increase in PCV smoke as well.
    Thanks for any help.
    175 Post(s)
    Have you noticed any changes in boost ??
    Low boost = Egts up, as they have to be in a certain harmony .
    Just a brainstorm idea . Maybe the boost controlling vacuum setup dislodged a hose or a leaking intercooler pipe somewhere due to corrugations you mentioned.
    Sent from my Pixel 6 using Tapatalk
  4. The Following 3 Users Say Thank You to Hodge For This Useful Post:
    10G (14th February 2023), Bidja (14th February 2023), MudRunnerTD (27th February 2023)
    May 2016
    lower west victoria
    30 Post(s)
    Boost may be down a little. Boost gauge is currently busted, I'll get that fixed up and see what it tells me.
    Thanks Hodge, that's a good start.
    462 Post(s)
    EGR valve could be jammed due to the corrugations?
  8. #5
    Yea, Victoria
    Clean your MAF sensor. Very easy job but often ignored.
  9. The Following 2 Users Say Thank You to Coldcomfort For This Useful Post:
    10G (14th February 2023), mudski (14th February 2023)
  10. #6
    May 2016
    lower west victoria
    30 Post(s)
    Now the MAF could be the problem, it was very dusty in sections.
    Thanks for the help folks.
  11. #7
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Just to add here, do a quick check of VNT actuator function (vacuum):
    at idle, is the actuator rod in the raised position, ensure that the lever is resting against vane limit stop screw? yes/no (should be yes), and
    then still at idle, pull the vacuum hose off the actuator rod should drop to bottom of stroke promptly? yes/no (should be yes)
    As mentioned _ Check that all boost hoses are fitting securely, check for splits/damage, loose clamps. Check your boost reference take off point, hose and connection for leaks.
  12. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    10G (15th February 2023), Hodge (15th February 2023)
  13. #8
    May 2016
    lower west victoria
    30 Post(s)
    Thanks @Bidja, I'll do all that. Just got out of the truck. She's running about 100 degrees hotter than it should and low on boost I reckon.
  14. #9
    Jul 2017
    37 Post(s)
    High EGTs, Guess this with eng under high load / hauling?
    Important to rule out any vac or boost faults / issues first. Good to get boost gauge working.
    What boost control method do u use?
    What engine mods?
    Let us know how it goes.
  15. The Following User Says Thank You to Bidja For This Useful Post:
    10G (16th February 2023)
  16. #10
    May 2016
    lower west victoria
    30 Post(s)
    Got the gauge going, it's only making half boost.
    Normally it'll peak at 15psi and sit on 13psi at 100kmh on the flat in 5th, that gives me 300+ EGTs.
    Today at 100kmh I was boosting around 5.5 with EGTs at about 500+
    I got both a Dawes and Needle valve.
    The only thing that I have done that could affect it was that I tightened up the large hose from the IC a while back, that's the only thing I've touched. That could have produced a leak I guess, it's the original hose, maybe it's overtightened?
    No engine mods.
    I'm going to check/replace all the small vacuum hoses around that area.
  17. The Following User Says Thank You to 10G For This Useful Post:
    Bidja (16th February 2023)
