Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Squeal from fan belt on start.
    Yea, Victoria
    Probably a bad idea. I think a big part of the reason it broke is the fact that the plastic has become brittle. I might investigate an all alloy replacement.
  2. The Following User Says Thank You to Coldcomfort For This Useful Post:
    BrazilianY60 (16th February 2023)
    175 Post(s)
    Would it be a bad idea to thread a brass barb onto the plastic radiator top thingo?
    I think it's been tried and tested. From barb's to plastic welding old one back one. Can't recall anyone having success.
    Sent from my Pixel 6 using Tapatalk
  5. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BrazilianY60 (16th February 2023), Coldcomfort (17th February 2023)
  6. #13
    Yea, Victoria
    Picked up my new radiator yesterday. Its made by Koyorad ($395 from Natrad). A Japanese company with a pretty good track record. Comparing it to the Nissan unit I really cant see any difference.
    Weekend full of Patrol reassembly coming up.
  7. The Following 3 Users Say Thank You to Coldcomfort For This Useful Post:
    BrazilianY60 (18th February 2023), Hodge (17th February 2023), mudski (17th February 2023)
  8. #14
    Quote Originally Posted by Coldcomfort View Post
    Yeah Koyorad radiators are really good. Built to factory spec. I have one in my Patrol.
  9. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Coldcomfort (18th February 2023), Hodge (18th February 2023)
  10. #15
    175 Post(s)
    When I bought a radiator from Patrolapart for my 3L back in the day im pretty sure it was Koyorad.
  11. The Following User Says Thank You to Hodge For This Useful Post:
    Coldcomfort (19th February 2023)
  12. #16
    Yea, Victoria
    After I removed the old tensioner I had a good look at it. The bearing felt smooth and easy to spin. No sideways slop and definitely no noise. But after some poking and prodding I discovered that the pivot bushing that the hydraulic spring in attached to the main body was as sloppy as a nuns shirt sleeve. I'm guessing that this slop would relieve some of the tension on the serpentine belt. Hence the squeal.
  13. The Following 2 Users Say Thank You to Coldcomfort For This Useful Post:
    Cuppa (20th February 2023), Hodge (20th February 2023)
  14. #17
    Legendary happygu's Avatar
    Just another thought for you Coldcomfort ... I had the squeal for ages - changed out my tensioner thinking it was gone as it is 'always' the tensioner, and the squeal went away for a few weeks - it returned and when i checked it properly it actually turned out to be the alternator pulley, which basically fell off in my hand after i found it. It should be fairly obvious with the tension off the belt when you look at it if that is it.
    Another thing to check....
  15. The Following 2 Users Say Thank You to happygu For This Useful Post:
    Coldcomfort (21st February 2023), mudski (21st February 2023)
  16. #18
    Yea, Victoria
    The burping has begun. Spent some time last night burping the radiator. All went well but I suspect that there may still be an amount of air in the system. I put the front wheels up on ramps and squeezed the hoses. Saw lots of air make its way out the radiator cap orifice. I'll do some more tonight but I thought I would ask if there is any "good" ways to do this? On my scan gauge the coolant temp never went above 86c. But I suspect that it will get to around 86 > 89 when actually driven.
