Results 1 to 10 of 17
Thread: TD42 not sounding right
    Jul 2021
    Hey guys, recently td42 swapped my tb42 efi gq. Engine is freshly rebuilt with a new head, 10mm pump is only 20,000km old, new injectors, brand new GTurbo green wheel with new manifold and gaskets and front mount intercooler. Only thing that's not new are the glow plugs so it struggles a bit to start when cold, when warm it runs rather good but there is a constant diesel knock/ticking noise that is quite loud hot or cold and increases with revs. I started to think the ticking was normal but I recently drove my mates td42 gq with 410,000km and the engine sounded like a petrol compared to mine. I used a stethoscope to try pin point where the noise is coming from and the majority is coming from the manifolds, especially the intake manifold. Driving me insane trying to work it out
    https://www.youtube.com/shorts/LKrLJv73VzM (Video of the sound)
  2. The Following 2 Users Say Thank You to lcorney For This Useful Post:
    AB (10th December 2022), MB (10th December 2022)
    473 Post(s)
    G’day Icorney Mate
    Surprised you’ve beautifully tricked the Beast up with expensive breathing pipework and kept a 20k unknown old 10mm injector pump Brother?
    My stupid iphoney nuffy speaker here full of sawdust kinda sounds like steel on steel gears ?
    473 Post(s)
    We should create a NEW thread Folks, how to Fark with a half deaf carnt
    Now it sounds like Tappets are in need of HOT adjustments
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Ticking or knocking... sounds like valve issue.
    These are pushrod engines. Inlets wear out, exhausts wear in. Or the other way around... you'll find out.
    Spec is 0.35mm HOT.
    Glow plugs generally either work or they don't. You can check the relay, earthing, and power to the rail...
    1989 LWB 5-Seat, TD42
    Patrol God Stropp's Avatar
    31 Post(s)
    I had a similar problem recently with the timing control valve aka tcv it knocks and rattles like mad if it can’t sense it as it runs the timing at full advance, could be the problem? Check the plug on the bottom of the diesel pump is connected to the wiring loom and also that the plug is tight.
    175 Post(s)
    Sounds like tappets to me.
    What oil / grade / brand are you using?
    Apr 2021
    Brazil
    Can you guys really listen something there? Just a cold engine to me...
    For example, listen to this audio and note the diference of the sound from the first minute to the last minute, when the engine is already at working temperature.
    https://youtu.be/O0ZoFY8o1AM
  10. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MudRunnerTD (12th December 2022)
  11. #8
    330 Post(s)
    Thats an interesting Vid. Grabbing a sound bight at 20 seconds and another at 4mins and there is a fair differesnce for sure.
  12. #9
    330 Post(s)
    Quote Originally Posted by lcorney View Post
    my initial thought when i started your video. (I did not read your full description above) was that you have an exhaust Leak. I still tend to think you do. That video posted by Brazilian is interesting though for sure. Load them both up and grab 3 sound bites. Still think you ahve an exhasut leak though. How muchg boost are you running? and under power are you getting the tuned boost at teh intake?
    A faulty or blown off PVC could make that noise for sure though as Stropp suggested.
  13. #10
    Jul 2021
    Sorry for the late reply guys, i have check the tappets (hot) multiple times and they're still in spec (0.35mm). I see no signs of exhaust leaks and the sound is mostly coming from the intake side of the engine. I'm running Valvoline super diesel 15w40 and Ryco oil filters. The sound is more noticeable at lower revs but I can constantly hear it through the firewall while driving. The 10mm pump is only temporary, I will be running a 11mm pump in the near future when I have enough funds. Cheers guys
