Results 1 to 2 of 2
Thread: Swap ZD30 for QD32 what electricals need changing
    Advanced
    Jan 2017
    Hi I have ordered a new long QD32 which I was planning replacing a TD27 in a Terrano but my sons IP has just gone on his ZD30 Navara , maybe it should go in there.
    If all the mechanicals of engine swap can be dealt with and the injection pump is mechanical not electrical controled ,, is it a matter of running one wire from ign to the fuel cut off solenoid and disregard the rest, apart from oil pressure sensor and water temp.
    Sorry I know this is a Patrol forum but I imagine Zd30 setups would be the same
    Thanks David
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    I'm sure it can be done. Cost-benefit and muck-around time though??
    I'm not sure if they have the same bell-housing pattern? Engine mounts? Diff ratios?
    Yeah bare minimum you need is fuel and air for a diesel engine to run.
    Then there's all the sensors etc on a modern engine... which I would think is where the real headache comes in. MAF an O2, knock sensors etc And they probably need the engine-specific computer.
    - 1990 LWB Safari flatdeck, TD42 -
    - 1988 LWB 7-seat Safari, TD42 -
    1989 LWB 5-Seat, TD42
