Results 1 to 3 of 3
Thread: Alternative to " start you bastard'
    Advanced
    Jan 2017
    hI, That stuff is very good on petrol motors, diesels have twice the compression. The stuff explodes when the piston is only half way up,,, not good,,, way too early,,, knock the shit out of your engine.
    Im no expert but I use a can of butane for gas cookers,, put a plastic head on it from an insecticide can, works for me , and only $1 instead of $14
  2. The Following User Says Thank You to Dagwill For This Useful Post:
    mudnut (22nd January 2023)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Per the MSDS for "start ya bastard" :
    "3. COMPOSITION INFORMATION CHEMICAL ENTITY CAS NO PROPORTION
    Solvent naphtha, petroleum, light aliphatic 64742-89-8 30-40 %
    Diethyl ether 60-29-7 10-20 %
    Hydrocarbon propellant, as 50-60 %
    Alkanes, C3-4 "
    So... mostly just napthalene/petrol.
    Does it detonate before TDC? I don't know, I'd need to see some kind of science to believe it.
    Being said, if you can't start a diesel engine with pre-heat/glow then you probably have an issue to sort out...
    Butane is just a lighter fraction of petrol distillate...if anything i would think -more- prone to detonate.
    - 1990 LWB Safari flatdeck, TD42 -
    - 1988 LWB 7-seat Safari, TD42 -
    1989 LWB 5-Seat, TD42
  5. #3
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Just gave it a google and butane has an octane rating of 92... so depending where in the world you find yourself, that's approx equivalent to pump petrol. (generall 89-98 octane)
