21st January 2023, 09:54 PM
Rear power outlet on a 2012 wagon?
Hi all,
I have just installed a second battery in my truck. Mainly to supply my fridge in the rear. There is a 12v outlet in the rear from the factory. I want to use this and use the existing wires. I have been told that I can intercept these wires behind the passenger kick panel. Has anyone else ever done this? Any info on wire colors etc?
Cheers all.
The Following User Says Thank You to Coldcomfort For This Useful Post:
Hodge (22nd January 2023)
21st January 2023 09:54 PM
22nd January 2023, 09:40 AM
Hey mate. Is your battery at the rear or under bonnet?
If it's up front. Honestly, you're far better of running a dedicated fused proper sized wire to feed the fridge at the back.
From memory that factory socket is 120W. I tapped into it during early days of owning the GU and the Volt drop was massive. Even when I gutted that rear passenger end, the wiring behind the socket was too small to feed 10 amps, it's supposedly rated to.
Just my 2c.
Edit: I forgot to mention I never spliced into it, I just used it off the factory battery as it was.
Coldcomfort (22nd January 2023)
22nd January 2023, 09:48 AM
If you decide to splice in. Here is what I believe it is from the Patrols service manual "LW" = Blue-white wire.
Attachment 86507
22nd January 2023, 01:51 PM
Hey Hodge, computer says no. Invalid attachment. I have the service manuals in PDF but they are a night mare to find what you might need. I'd be keen to see what you found.
22nd January 2023, 01:54 PM
Interesting why it didn't work. I'll try again here.
The Following 2 Users Say Thank You to Hodge For This Useful Post:
BrazilianY60 (23rd January 2023), Coldcomfort (22nd January 2023)
5th February 2023, 02:14 PM
I found it
Hi all,
after some poking around I identified the wire that connects to the rear power outlet in the rear of a 2012 wagon.
Its is a green wire with a red trace. Hopefully the picture will convey more info than I ever could hacking away at the keyboard.
6th February 2023, 08:35 PM
I finished off the rear power socket to the second battery today. When the car engine is off the voltage at the second battery is 12.88v. Voltage at the socket in the rear is 12.12v. Not too bad but will see when its under load.
The Following 3 Users Say Thank You to Coldcomfort For This Useful Post:
BrazilianY60 (7th February 2023), Hodge (7th February 2023), MB (6th February 2023)
7th February 2023, 06:55 AM
Coldcomfort
Great to see you've sorted it out.
That's a considerable unloaded volt drop.
Will be interesting to see what it does under pressure.
Sent from my Pixel 6 using Tapatalk
7th February 2023, 08:18 AM
Coldcomfort
As Hodge mentioned mate. Run a dedicated live wire to the back for your fridge. That drop is too much and its not under load. When the fridge kicks in and its a hot day and the fridge needs all the help it can get. This setup will fail for sure.
I run 6 B&S cable to the back for my fridge. V drop is circa .06v. Going by my last measure at Christmas...
7th February 2023, 09:32 AM
Coldcomfort
Something is definitely wrong here. With no load (except the voltmeter) there should be negligible voltage drop. Might pay to re-check your readings and re-do your wiring if those readings are repeated.
Both the positive and the earth need to be solid to run a fridge.
Check the voltage between positive at battery and positive at your fridge point, and also earth/negative at battery and at your fridge point to see which one is your issue. These should be zero.
