Results 1 to 4 of 4
Thread: Clutch question
    Sep 2015
    Clutch question
    Hi guys,
    My Y61 has a slow leak from the master cylinder. I thought I might as well replace the slave cylinder as well, so I've got both. Should I do them in any particular order? Or something else I need to think about.
    Peter
    465 Post(s)
    You'll need to bleed the master first, once done, then the slave.
    Sep 2015
    Thanks mate!
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Unless they've changed much, the slave can be given a light hone and a standard 3/4" hydraulic cup seal to refresh it.
    The masters -apparently- (I haven't checked) had a hardened bore and any attempt to hone is -apparently- likely to cut through that, so best replaced.
    Not sure if the '61s enjoy the same stupid tee, coil, and bleed nipple up by the diesel filter (passenger side) but if they do, it makes it a whole lot easier to either blank it off at the tee (1/8" bsp plug), or bend the coil about 90 degrees so the line is all up-hill and won't trap air bubbles.
    Bleeding is done in your preferred method. Pressure bleed or vacuum bleed easiest if you have the kit.
    1989 LWB 5-Seat, TD42
