6th January 2023, 08:54 AM
Dash guages and auxiliary guages turn off with wipers
As seen in title when I use my wipers my guages on dash and auxiliary gauges turn off. Aswel as my Parking lights won't turn off other then pulling the fuse. Half my dash also died. Anyone have any ideas if it could be a relay or bigger wiring issue.
6th January 2023 08:54 AM
6th January 2023, 10:55 AM
Welcome to the forum. Check your trailer socket and its wiring loom. Other than that, it could be an earthing issue, either at the dash or from the engine to the chassis or chassis to the body. It pays off to remove the earth wires clean the connections and refit them. It also helps to add a couple of extra earth cables.
The Following User Says Thank You to mudnut For This Useful Post:
