Results 1 to 2 of 2
Thread: Water leak - solved
    Jun 2020
    Water leak - solved
    I’ve had carpet wet after rain. I sealed firewall holes which didn’t fix it. I reseated the windscreen which didn’t fix it. I taped the rear side windows which did.
    This has completely solved my leak into the cabin.
    I used t-Rex water proof tape. It’s very aggressive adhesive and uv stabilised. $20 for 2m from Bunnings. You’ll need two rolls to do both rear windows.
    80 Post(s)
    I found that the window which was fitted just before I bought my Patrol, had the corners made with too much radius cut, which let water dribble in. A thin bead of Sikaflex around the rubber at the corners fixed it.
  4. The Following User Says Thank You to mudnut For This Useful Post:
    mantaray07 (16th April 2023)
