Results 1 to 7 of 7
Thread: Fuel filter housing and return valve
    Dec 2022
    Hi all, on top of the fuel filter housing is that the return valve?
    ZD30 2000 model non common rail engine.
    I am not finding a manual that has this valve there on the housing.
    Br. from Iceland
    Elmar
    194 Post(s)
    @nissannewby, can you help this guy?
    194 Post(s)
    @mudski, sorry Mark, right up your alley I would think
    Dec 2022
    This is a part for cold climate but i can not find good info on it.
    Br.
    Elmar
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I'm guessing it allows warm fuel from the engine to heat the fuel coming from the tank and is probably not used above a certain temp.
    Apparently 60c is a good temp for diesel for atomization.
    2008 CRD Auto Wagon
    194 Post(s)
    Quote Originally Posted by pollenface View Post
    From what I have researched, diesel fuel temperature above 48degC starts to lose calorific value by something like 1% per degree, hence why there are fuel coolers on some of the common rail engines to help control this variance. I intend to measure my fuel just out of curiousity, however dont expect to find much info of value to be honest. Good to know what the function is of the device though.
  8. #7
    Nov 2019
    Perth
    5 Post(s)
    You might be right, I'm just going off some stuff I read on a canadian trucking forum.
    2008 CRD Auto Wagon
