Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: TD42 not sounding right
    What spec is the injector pump timing set at?
    Who rebuilt the engine?
    Jul 2021
    Injector pump timed at stock spec, I forget what it is now. I have tried advancing it and retarding it which made no difference to the noise
    Rebuilt by some bloke on the goldy that does td42, 1hd
  4. #13
    Ok. I have seen engines tick when the rings were tight in their lands after a rebuild. Could be something worth checking.
  5. #14
    Jul 2021
    What would be the process in checking that? Should I contact the rebuilder or can I check that myself? I have also just checked my catch can 4000Km after rebuild and I was surprised that there was actually a bit of oil in it since its new I thought there'd be no blow-by.
  6. #15
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Quote Originally Posted by lcorney View Post
    Rings will take some time to lap into the cylinders...
    The builder should have given you a break-in proccess... oil change interval etc
    And ah, if you could check ring gaps, you coulda rebuolt the engine... not a five minute job.
    1989 LWB 5-Seat, TD42
  7. #16
    Sep 2014
    Have you checked if the power goes off from glow plugs. Constant power on glow plugs caused a rattling noise from my td42...
  8. #17
    Apr 2021
    Brazil
    Quote Originally Posted by Ilvesekesekene View Post
    That would cause pre-detonation I assume?
