24th October 2022, 12:15 AM
MudRunnerTD
Thanks mate, that's what I was looking for. I will drop it on the ground and try and get it to 2mm. Measuring off treads alone with a tape measure there is almost certainly 1mm in it.
If you know the thread pitch of you tie rod ends then this is quite easy. For example if the tie rod ends have a 1mm pitch then 1/2 a turn would equal approximately 1mm off your measurement. Remembering you have 2 tie rod ends so the 1/2 turn is 0.5mm for each end or 1mm in total.
BrazilianY60 (24th October 2022), MudRunnerTD (24th October 2022)
24th October 2022 12:15 AM
24th October 2022, 12:17 AM
Do you have a laser distance finder/measuring device? Possibly at work.
24th October 2022, 09:04 AM
Moderator
nissannewby
Hahahaha Every working day of my life for the last 20 years i have had one in my hand. That will make the job way way easier. Im a goose! Thanks legend.
Check out my Toy -->
Rogue Dung Beetle
24th October 2022, 10:12 AM
Having a little trouble with some of the figures mentioned in this thread.
If the tyre diameter is 818mm and the width is at the front of the tyre is 1406mm and at the rear is 1409mm (that's how I interpret the OP's figures):
The 'toe-in' on each tyre (assuming equal on each) will be (1409-1406)/2 or 1.5mm.
Using basic trigonometry, the sine of the angle of the 'toe-in' is 1.5/818 (opposite over hypotenuse) = 0.0018337408312958.
Using inverse sine this equates to an angle of about 0.105degrees.
Does that make sense or have I got it all wrong?
The Following User Says Thank You to Brissieboy For This Useful Post:
24th October 2022, 12:41 PM
Moderator
Brissieboy
Thank you. Trig was not my thing 35 years ago and still isn't. Lol. You are probably very right, Plasma and Peebee are also bang on.
My memory was 2 degrees but it seems outrageous. Maybe I remember 0.2 degrees whoch makes way more sense.
Thanks everyone.
Rogue Dung Beetle
30th October 2022, 03:08 PM
if were talking a soild axle then just set it to 0 toe and it will be fine
gone to the dark side 2017 vdj 79 dc
