Results 1 to 10 of 13
Thread: [Vic] TD42 factory low radiator guard/support
    Jun 2018
    24 Post(s)
    Item for sale:
    Factory radiator support/guard for low mount radiator (TD42/TB48)
    Price:
    Make an offer
    Condition:
    Used, excellent condition
    Details:
    Removed because I fitted a Billy Goat bash guard.
    Inner Melbourne. Can post at buyers expense.
    Contact:
    DM if interested
    473 Post(s)
    Nuffy Oldish Fart Query Ash Mate
    What is a “Billy Goat Bashguard” ?
    Dearly hoping it’s not a reversing whilst bogged steel sand/mud anchor
  4. The Following User Says Thank You to MB For This Useful Post:
    Cremulator (22nd October 2022)
    Jun 2018
    24 Post(s)
    Haha yep, it is.
    This is the photo of it from their website.
    But a wise man once said "big believer in stock designed positive/negative air pressure zones now.
    Many a great sand driver folks hate these ‘Air Dams’ as they ‘rip off’ when reversing have read but do believe down here they are integral for our highway needs."
    I fitted this to mine mostly for the air flow/air pressure while driving on the highway as mine didn't have the factory guard, like this, when I bought it
    (Source http://www.nissanpatrol.com.au/forum...l=1#post792459)
  6. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (22nd October 2022)
  7. #4
    473 Post(s)
    Wise highway advice Brother Ash
    Please do go easy on damaging tracks too, it has been documented that aftermarket steel dams dented/bent hinder steering capabilities deep off-road careful
    May I ask if your Beautiful TD42Ti is possibly overheating?
    May have some hopefully helpful proven OEM tricks
  8. #5
    473 Post(s)
    FWIW: We ALL forget to consider our GQ & GU A/C Condenser’s out front and out bush and or highway hauling.
    TD42’s were poorly designed on the brink of Kettling out of the factory without Australian dirty/dusty fins.
    Imagine slapping a piece of half blocking ‘Coreflute’ in front of our radiators
    ……Holistic TD cooling needs view, wash/degrease lightly your Condenser’s too
    FWIW2: Just done this last week on my Ex’s TD42T and dropped it back by 10C to where I had it prior singing safely
  9. The Following User Says Thank You to MB For This Useful Post:
    Cremulator (23rd October 2022)
  10. #6
    473 Post(s)
    FWIW3: Top tip, high volume, low pressure water is key to clearing fins without damage
    A standard garden hose reduced to a say 1/4” air line type fitting and say 20 minutes cleaning each side at least will drop 10C and no need to OEM replace unless the inner cores are knackered
  11. The Following User Says Thank You to MB For This Useful Post:
  12. #7
    Jun 2018
    24 Post(s)
    It's been pretty stable temp wise.
    The peak temps I saw on our recent trip to Fraser island, fully loaded with two Expedition 134 boxes on the roof rack, were 95° and EGTs at 525°. Backing off/changing gear saw these drop pretty quickly.
    This was with the Billy Goat guard installed. I'm not sure if it has much effect, but I wanted to reinstate aftermarket pieces that aid cooling the same as factory items to avoid the potential of creating an engine that has overheating problems.
    I made this other guard to channel air flow through the radiator and prevent sticks going up through that gap.
  13. The Following 2 Users Say Thank You to Cremulator For This Useful Post:
    BrazilianY60 (23rd October 2022), MB (23rd October 2022)
  14. #8
    sunshinecoast
    hi cremulator . that is the first time i've seen the standard plastic air dam . that steel plate from the bullbar to thechassis might be a problem , on the zd30 with the wide shallow radiator it is good but on the td42 with the narrow deep radiator it seems to be a hinderance to cooling air flow . on the other patrol site there is a thread called AERO THINGS & HEAT MANAGEMENT ( COOLING SYSTEM ) . it is full of interesting info on td42 cooling issues .
    i just looked at that pic of the plastic air dam again . is that on a zd30 ? did td42s have the plastic air dam?
  15. The Following User Says Thank You to nipagu7 For This Useful Post:
  16. #9
    Patrol God Stropp's Avatar
    31 Post(s)
    I have a similar setup and on the beach at 10 psi tyre pressure in sift sand no temp problem, mind you I did fit the hi flow ufi fan and hub.1B8A73FC-DA67-4298-B061-EEDAECE5B221.jpeg
  17. The Following User Says Thank You to Stropp For This Useful Post:
  18. #10
    Jun 2018
    24 Post(s)
    Quote Originally Posted by nipagu7 View Post
    @MB took that photo of the plastic air dam, I'm not sure which vehicle it was fitted to.
    The plate from the bull bar to the chassis I made with the intention of replicating the factory plastic dam that was fitted to my aluminium bull bar.
