2nd October 2022, 08:30 PM
rd28 starting issue
Hi guys,
Having problems with starting my RD28 patrol, will start with "start ya bastard and will start again with every try within the minute, if i let it sit for 20mins wont start again without the spray", injector pump replaced, timing is 100% all good, fuel filter brand new, primer stays hard glows plugs new, all belts done, has fuel in tank,no idea where to go from here
leaning towards something to do with the fueling.
Qns:
Could it be the timing of pump, if advanced would it help starting?
2nd October 2022 08:30 PM
5th October 2022, 01:36 AM
Check/set valves.
New glow plug wont help if no power getting to them. (check controller)
Sucking air to injector pump? Solenoid there staying on? (check relay)
1989 LWB 5-Seat, TD42
Or you might have just given her an ether habit :/
The Following User Says Thank You to mihit For This Useful Post:
5th October 2022, 09:36 PM
