Results 1 to 10 of 10
Thread: Advice on cleaning ZD30 injectors please
    Jan 2017
    Hi, I have the injectors out at the moment and was wondering if i should clean the nozzels.
    Looked closly at the end and I cant see any little holes at all.
    Is it reletivly easy to put them in a vice [pointing upwards ] unscrew the nozzel [ remove with care ] and check and clean them.
    Or, I noticed on Ebay new nozzels were $100 each , is that a better way to go.
    Or give them a scrub and just put them back in. ??
    175 Post(s)
    Don't quote me on this.
    But I believe injector cleaning requires specific bench setup, tools and very precise measuring equipment. Something best left to properly setup diesel workshops.
    (if you have these and have the know-how please disregard this comment).
    Injectors (especially common rail ones I believe) are super fine and need a precise spray type, pressure etc...
  4. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    Dagwill (2nd October 2022), mihit (30th September 2022)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Hodge is 100% correct. If you have to ask - you're not equipped to fuck with it. You -could- put them in an ultrasonic cleaner if you know how to use one and you -could- make a bench-tester with an old hydraulic bottle jack. But mostly: just don't.
    That said, since you already have them out, what you'll want to do it pull the injector-mount (or "ZD30" as you call it) out of the vehicle and replace that with a Proper Engine
    1989 LWB 5-Seat, TD42
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    If you can find someone who does them on an exchange basis, that would be the way to go.
    I've no idea what "ebay" injectors are like.
    And I wouldn't "scrub" them. You can't see the hole, but it's there, and if you clog it with wire bristle or other shit, it's going to be worse than before.
  7. The Following User Says Thank You to mihit For This Useful Post:
  8. #5
    Jan 2017
    Thanks, i will take on board what you all said,,,, theres been more than one time in my 67 yrs that ive said to myself. "That would have been fine if id left it alone"
    That said what I intend to do is refit the injectors , but not down into the engine but sticking straight up. crank it over and observ the spray, if they are reasonable ill refit them , if they look bad ill get a specialist to service them.
    Thanks for the good advise.
  9. The Following User Says Thank You to Dagwill For This Useful Post:
    mihit (1st October 2022)
  10. #6
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Quote Originally Posted by Dagwill View Post
    That's not silly. And is reasonably safe on a direct-injection. (DI sees 1/5th the PSI that common rails use)
    Just be very careful to keep yourself out of the way of the spray/nozzles as even a few thousand PSI will push diesel through your skin and into your bloodstream (google injection injury) which will really ruin you day.
    And safety specs/eye protection.
    Also the usual sensibilities about having your assistant light your cigar or pipe well away from the work area, and not to make or break any electrical connections or otherwise cause sparks while there's atomised diesel about...
  11. The Following 3 Users Say Thank You to mihit For This Useful Post:
    Dagwill (2nd October 2022), jack (1st October 2022), MB (1st October 2022)
  12. #7
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Naturally I googled it, interesting images.
    Jack
  13. The Following User Says Thank You to jack For This Useful Post:
    MB (2nd October 2022)
  14. #8
    473 Post(s)
    Linky www.dotti please Jackstar
  15. #9
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
  16. The Following User Says Thank You to mihit For This Useful Post:
  17. #10
    Expert pollenface's Avatar
    Nov 2019
    Perth
    5 Post(s)
    I use fuel doctor and hope for the best
    2008 CRD Auto Wagon
  18. The Following User Says Thank You to pollenface For This Useful Post:
    Hodge (6th October 2022)
