4th August 2011, 12:35 AM
RIP - valued member and true gentleman of this forum that will be missed by many!
GQ front clunk when brakes applied
G'day,
My Mav makes a lightish clunk when brakes are applied eg in a car park situation, reverse, brake, drive forward, brake, clunk.
Now, nothing under the seat is rolling around, I haven't run into anything at the time I hear the clunk).
What should I be checking? I know a little bit about radius arm bushes but not much. I don't feel it in the front floor, which I gather is common with radius arm bushes.
Thanks in anticipation.
4th August 2011 12:35 AM
4th August 2011, 12:37 AM
Dribble Master
well it wasn't me, I'm miles away!!!!!.................... roflmao
sorry couldnt resist
The Following User Says Thank You to Clunk For This Useful Post:
4th August 2011, 06:20 AM
Put a spanner over everything in the front end, steering and suspension. I know you said you can't feel anything but have a close look at the radius arm bushes anyway.
Check the drag link and tie rod ball joints/rod ends for wear.
Have a close look at the front brakes, make sure everything is tight and the pads are a neat fit in the slides.
Tony
The Following 2 Users Say Thank You to YNOT For This Useful Post:
Clunk (5th August 2011), Silver (6th August 2011)
4th August 2011, 08:10 AM
Banned
Hey Rick
More than happy to slip around to your joint tomorrow morning or over the weekend to have a look if you'd like a hand. Just let me know.
Other than that, as Tony said, check all joints, bushes for wear, nuts/bolts etc on all suspension items on the front end .. and maybe check brake calipers/bolts and wheel nuts also (remote chance of being these, but if you're under there, you may as well check them!!).
The Following User Says Thank You to Bigrig For This Useful Post:
6th August 2011, 12:38 AM
Thanks Tony, Clunk and Scott
I did replace bearings from the swivel hubs out, and the brake linings, so will arrange some time on Sunday mid morning on to get comfy underneath and tighten everything up. Thanks for the tips, there are a few things there I wouldn't have thought would be candidates, but were disturbed in the rebuild.
11th August 2011, 02:27 AM
hey matey,
have you checked for the pads actually slippig back and forwards on their retainers? Its usually a cruiser problem but it can happen on most vehicles. pbr makes a specific glue for this purpose, i forget what its called, but it helps the pad backing to stick to the piston to stop it clunking backwards and forwards. It may only move a little but it can make a serious sounding noise. Also if the retainers are worn and allow more play or if you have aftermarket pads that do not fit as well as genuine that can cause it.
The Following User Says Thank You to Kelvinator For This Useful Post:
growler2058 (11th August 2011)
